Snow Plow only turns one way
   / Plow only turns one way #1
Komrade
Western Morgan County, WV
Kubota L3430 HST
Still a newbie. First time plow user.
Plow only seems to turn one way (right).
How to I diagnose?
   / Plow only turns one way #2
Try pushing lever hard to the right. Some Kubotas require pushing through the detent to get movement. It seems weird pushing the lever so hard to the right at first.
That lever seems to go only up/down, and bucket moved reeeeeaaaaal slow To the right) when it did. Lever is not same as for front bucket. Are we talking about the same thing? Can post picture in AM.
   / Plow only turns one way #4
You are using the joystick to operate your front plow correct? It should move up/down and left/right, this is normally how front plows are controlled. If this is not correct then please give us more details on your particular setup, the devil is always in the details...and your question doesn't give many.
What moship is referring to is called "regen" or the regenerative function of the FEL valve (joystick). A search of the tern "regen" will turn up hours of reading.
   / Plow only turns one way #5
I was thinking you were using the conventional joy-stick used for front end loaders abd the FEL was replaced with a blade. Many first time users of snow blowrs with hydraulic rotation or angle blade users don't realize the joy stick had to be pushed much further to the right past a somewhat stiff detent.
You might want to verify the hose routing and reconnect all hydraulic fittings to just to make certain.
It might help if you described what plow/brand/model/etc...
   / Plow only turns one way #6
Not trying to be a smart***, but check your hydraulic couplings. My plow quit moving one direction a few weeks ago as well. Turns out one of the quick disconnect for the hydraulics wasn't seated all the way when I hooked up the plow, it worked for a while then suddenly popped out. The connectors were still partially engaged, so the problem wasn't very visible since the hose wasn't just hanging there.
   / Plow only turns one way #7
Your situation can happen if the hydraulic lines are cross plumbed. It turns one way because cylinders have more push than pull because the area of the rod doesn't contribute to force generation. If these are two single cylinders mechanically connected to act as a single, double acting cylinder, you are applying pressure to both sides instead of a pressure and return connection.
The FEL doesn't move left/right, hence additional controls. The plow is connected via quickattach and 2 additional hoses. Will check connections and brand in the morning. Picture of additional controls.
While I will don't know which way is open for the valve (despite the instructions), I played with all settings
Plow pic
   / Plow only turns one way #10
Komrade, the ball valve in your photo doesn't look like something rated for hydraulic pressure use! If you can post a photo of you plow's cylinder(s) and the lines, someone may be able to help more. I have a single cylinder, and my plow (also a SSQA snow blade) will turn both ways even when engaged with a push pile of heavy snow.
UNUSED FUTURE EXCAVATOR COMPACTION WHEEL (A51244)
UNUSED FUTURE...
2009 GREAT DANE 53FT REEFER TRAILER (A52141)
2009 GREAT DANE...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
2011 Chevrolet Traverse 1LT SUV (A50324)
2011 Chevrolet...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51242)
2021 HAMM HD+9I VO...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
