Please tell me this is not the way oil filters are made...
   / Please tell me this is not the way oil filters are made... #22
What? This can't be so, can it? I recently saw a tractor filter made in India or maybe Pakistan.
It says car filters but a lot of guys shop for crossover deals for tractors and the cheapest price so who knows what you get?
Those are most likely for local use. There are a lot of fascinating YouTube vids showing raw-labor manufacturing of products such as nuts/bolts, engine blocks, stoves, motors, etc.
If you’ve watched the above video, now watch the following one showing filters made in a Fram factory. The steps are the same, the process is different. Although I don’t recall seeing “sealant” being applied to guard against leakage in the Pakistan process.
The worst service I've had from oil filters is Fram. I wouldn't run them if they were free. Saw two come apart inside and suck the filter element thru the oil pump. When you tear the engine down it looks like a mouse has built a nest throughout the entire engine.
If you research it seems AC Delco has the best or almost best reputation. Wix also fairs well.
I've given up on Fram. I wonder if the high end ones are any better? AC Delco I can get but Fix is hard to find unless I get the NAPA numbered one.
For tractors, I go with OEM only. Is that wrong?
   / Please tell me this is not the way oil filters are made... #24
NAPA & Wix are good.
   / Please tell me this is not the way oil filters are made... #25
The following is a filter cross reference that I use quite a bit. Use discretion…..
   / Please tell me this is not the way oil filters are made... #26
I put some faith in OEM. I use OEM when dealing with the road grader. It's under warranty and I try to not give the manufacturer an "out" if anything goes wrong. Use OEM engine oil.
   / Please tell me this is not the way oil filters are made... #27
Some pretty interesting YouTube videos on comparing filters:
   / Please tell me this is not the way oil filters are made... #28
I use AC Delco on my Yukon, Wix on my mower and just bought a new Tacoma and will use a Toyota filter (made by Denso) until the warranty is over. I noticed that a Toyota OEM filter was almost half the price of a Wix. But it’s hard for me to believe Toyota would use crappy filters on their products. Never used Fram, but I know folks that swear by them. Oh well, to each, his own.
   / Please tell me this is not the way oil filters are made... #29
I’ve been buying NAPA Gold filters for several years. I used to use Fram but starting seeing bad press about them and realized they were junk. I’m not sure what I’m paying for the NAPA filter but around $14 after tax
These are just the ones I had on the shelf
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A57193)
UNUSED RAYTREE...
John Deere Hopper Assembly Kit (A56469)
John Deere Hopper...
Scotsman Ice Maker (A56469)
Scotsman Ice Maker...
2012 Ford Fusion Hybrid Sedan (A55853)
2012 Ford Fusion...
5' MOWER (A52706)
5' MOWER (A52706)
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52705)
2017 FECON RTF140...
