Please help
/ Please help #1
russellandgail
John deere d130
Hi guys, would anyone have an electrical schematic for a john deere d130 ride on please?
/ Please help #2
Should be able to go to your Deere dealer and ask them to bring up the schematic for you to look at, and usually they will print off a copy for you to take home.
Or you can order your own copy of the service tech manual.
Welcome to TBN
/ Please help #4
Welcome. Sounds like you are fishing for a particular problem. Feel free to impose!
/ Please help
Hi, yea got a fault on the ignotion line that pulls the starter motor coil in, got 12v leaving the ignition sw, but not arriving at the coil tested most switches, just need to see the full circuit to fault find
/ Please help
Yes I can hear it pull in but need to know what the contacts on it are, hence wanting a circuit diagram
/ Please help #7
You should have 12 volts on one small solenoid terminal when the key is activated and ground on the other. If you hear the solenoid activate, but the starter doesn't go- jumping the 2 large terminals on the solenoid should make the starter turn. If this is true, the solenoid is likely toast. The PTO sensing switch under the dash, brake switches must both be depressed to complete the starting circuit. If the engine is trying to turn, but can't- that is something else...
2013 Vermeer Vac-Tron LP855SDT T/A Vacuum Trailer (A64194)
2013 Vermeer...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2022 EZ-GO ELITE...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
