please help
/ please help #1
sowers35
catlett,Va
John Deere 790
790 John deere. Grinding and clanging after going in gear
/ please help #2
can you be more specific.
you clutch, put in gear, let out clutch and you hear banging?
what else... does it move like normal or no?
is the banging from? where? the trnny or gear case? or?
is it 4wd, and is 4wd engaged?
does it not bang if not moving?
/ please help #3
/ please help #4
Sounds like a clutch about gone or in need of a serious adjustment. Take up some of the thread on the clutch pedal if its grinding while going in and see if it stops. If its grinding while in gear, could be an e clip that has let go and your synchronizers are banging into each other in your tranny. If it's the latter, you need to stop using the tractor before additional damage is done.
/ please help #6
Welcome to TBN..
A friend of mine had a similar problem with his 790. On his, the differential lock stuck and he chewed some teeth off the right side gears. It would bang and grind as he tried to move it. I helped him replace the gears and freed up the diff lock. Not sure if your problem is the same or clutch related.
/ please help #7
Welcome to TBN..
Could be this also George but motion should be compromised if it's differential gears. I did this with my 750 as well shearing off the differential bolts. Lost all motion in rear wheel drive. Unless the op gets back to us as SG had requested with more details, all of us are just guessing trying to help the op.
/ please help #9
I thought the 790 was a collar shift tranny - no synchromesh gears. Stop before you shift and then you can better listen to the grinding when you shift!
AKfish
/ please help #10
AKfish
I'm glad to see you're back after your long absence.
Jim
/ please help #11
Thanks, Jim. It's good to be back... and workin' with both legs!
AKfish
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
2021 PETERBILT 367 (A67714)
2021 PETERBILT 367...
2025 Swict 78in Bucket Skid Steer Attachment (A66734)
2025 Swict 78in...
2006 Western Star 4900 Concrete Mixer U98358 (A62613)
2006 Western Star...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
PALLET OF MISC TRAILER PARTS (A68842)
PALLET OF MISC...
