please help
/ please help #1
sowers35
catlett,Va
John Deere 790
790 John deere. Grinding and clanging after going in gear
/ please help #2
can you be more specific.
you clutch, put in gear, let out clutch and you hear banging?
what else... does it move like normal or no?
is the banging from? where? the trnny or gear case? or?
is it 4wd, and is 4wd engaged?
does it not bang if not moving?
/ please help #3
/ please help #4
Sounds like a clutch about gone or in need of a serious adjustment. Take up some of the thread on the clutch pedal if its grinding while going in and see if it stops. If its grinding while in gear, could be an e clip that has let go and your synchronizers are banging into each other in your tranny. If it's the latter, you need to stop using the tractor before additional damage is done.
/ please help #6
Welcome to TBN..
A friend of mine had a similar problem with his 790. On his, the differential lock stuck and he chewed some teeth off the right side gears. It would bang and grind as he tried to move it. I helped him replace the gears and freed up the diff lock. Not sure if your problem is the same or clutch related.
/ please help #7
Welcome to TBN..
Could be this also George but motion should be compromised if it's differential gears. I did this with my 750 as well shearing off the differential bolts. Lost all motion in rear wheel drive. Unless the op gets back to us as SG had requested with more details, all of us are just guessing trying to help the op.
/ please help #9
I thought the 790 was a collar shift tranny - no synchromesh gears. Stop before you shift and then you can better listen to the grinding when you shift!
AKfish
/ please help #10
AKfish
I'm glad to see you're back after your long absence.
Jim
/ please help #11
Thanks, Jim. It's good to be back... and workin' with both legs!
AKfish
HORST RSW HEADER CART (A64278)
HORST RSW HEADER...
2009 Ford F-450 Ambulance (A64556)
2009 Ford F-450...
2022 Forest River GANS58SA 8ft. S/A Enclosed Cargo Trailer (A64557)
2022 Forest River...
1999 INTERNATIONAL 4700 - 6 WHEEL GRAIN TRUCK (A64278)
1999 INTERNATIONAL...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2020 BROWN AND HUBERT 10' SPOOL TRAILER (A63276)
2020 BROWN AND...
