please help with T L B
/ please help with T L B #1
raymond
I am in the market for an L48 type tractor, like the looks of the Earth Force machines but I can not get a dealer to call me back. I wonder if anyone has experience with a front mounted auger on an L48 and if so how it worked. I currently borrow a skid steer to auger with, I own the auger, my brother owns the skid steer, but I would like one machine to auger, dig, move dirt and stone. I quger in clay-sand soil for mobile home foundations.
The auger is a lowe brand with a 24 inch auger that requires 16 gpm at 2000 psi, can i put on a bigger pump or will 12 gallons per minute just not work as well.
/ please help with T L B #2
Raymond:
I've not done the type of work you're doing, except the hole drilling. My Power Trac 1845 has 15gpm @ 3000 psi hydraulic PTO. Its bucket capacity is 1200 lb, to 72" lift. It gives you front mount like a skid steer, but more stability. I wouldn't give up on the Earth Force, but suggest you take a look at the Power Trac. If you search for the Power Trac customization thread, I posted pictures of the WR Long 4 in 1 bucket and the Lackender hoe for mine. You might find a similar rig does your jobs pretty well.
/ please help with T L B #3
Raymond,
I think that what you'll find w/only 12 galllons a minute the auger may "stall" often if you get into rock or hard-packed clay.I would give Lowe a call and see if they could tell you how the auger would perform on only 12 gal/min,they may say its fine.The other choice is to sell the hydraulic auger and buy a 3 point hitch auger to go along w/the new machine,I have a 3 point hitch auger and it works great,it also would allow you to use the front bucket w/out disconnecting anything.I also tried looking into the EF machines w/out much luck,but at the time they were being aquired by Ingersol Rand and I think there may have been issues w/them and some of the dealers,but if that is the best machine for you then keep persuing it,Mark Chalkley really loves his and it seems to work like a bear,check out some of his posts (Goodbye Kubota,hello EF or EF enhancements)he is EXTREMELY knowledgeable about it.
/ please help with T L B #4
You could get a PTO hydraulic pump. I think Prince makes one that puts out 20 GPM at 540 PTO.
/ please help with T L B #5
Raymond - What part of the world do you live in? Jason @ Folcomer Equipment has been on a vacation & ConExpo trip, but will be back in the office Monday. He may not be close to you, but he will return your calls, he's a great guy to work with, and he can work nearly anything out as far as delivery goes. Depending on the size machine you're interested in, you may be able to get it from any Bobcat dealer (EF-250 or smaller). Otherwise, check with anyone that carries Ingersoll-Rand equipment - they can probably get the larger ones.
Also, you can e-mail me your phone number, and I guarantee you'll get a call from somebody at EarthForce within a day or two.
As for hydraulic flow and augers, here's the deal: Flow determines the speed the auger turns, and pressure determines the amount of torque developed by the motor. For example, my McMillen auger head manual includes a table that shows the speed of rotation for all the flow rates that head will operated at. But, regardless of flow, a separate table shows the torque produced at 2000, 2500, and 3000 psi. As for digging ability, if the flow is too low, the auger won't dig as fast, and it won't clean the hole out as well - but it'll still dig in tough conditions, just more slowly. If you were to put your auger head on an EarthForce machine, though, you'd need to make sure it can handle 2900 PSI, or has a relief valve.
May the Force be with you! /w3tcompact/icons/wink.gif
I just want to say thankyou for your responses it has helped a lot. I called folcomer equipment and talked to Dave who was a great help and is sending me pictures of a used EF-4 soon. I think I will go that way.
/ please help with T L B #7
Raymond - You're welcome! By the way, I've driven that EF-4, probably. At least, I've driven several of them at Folcomer's. Let me know how it goes.
mark can you tell me what kind of shape they are in, I live in michigan and do not want to waste a lot of time if they are subpar.
thankyou
Ray
/ please help with T L B #9
Raymond - I saw, but didn't drive, an EF-3 that was in "very used" condition. Mechanically, I'm sure it was sound, because it was regularly being rented, but it looked quite rough. Except for that machine, I saw EF-4's that ranged (in appearance) from very good to almost new. So, it depends on which one he's offering you, of course, but any of the EF-4's looked fine to me. I drove three different ones, at different times, and they all worked perfectly.
What are you planning on doing? Are you going to drive down to look at them? Can you haul it yourself or will it have to be shipped?
I was thinking I would drive to look and probably get it shipped. I own a dodge 3/4 ton pick-up, do you think I could haul it on a pintle hitch trailer or would I need a goose neck, if I decided to haul it my self. I saw an EF 3 this weekend in indianapolis and was very impressed with it beefy apperance but I thought it was a little small for my needs, I think I will go with an EF 4 but I would like to see and drive and dig with one first. I really appreciate you help with this.
Ray
Ray
/ please help with T L B #11
Ray - I routinely pull my EF-5(00), 4-in-1 FEL bucket, auger head, 18"/30" auger, 1.5 cu. yd. FEL bucket, pallet forks, and 18" and 24" backhoe buckets on a three-axle ball-hitch trailer behind and '93 W250 Dodge Cummins 6-speed. That's grossing over 27k. The truck brakes have been beefed up, the tranny upgraded, engine upgraded (a lot), and there's 54k worth of brakes under the trailer and a weight distributing Reese Titan V hitch to hold 'em together, so that's part of the deal. There's several pictures of the EF-5 on my trailer behind a friend of mine's '92 Dodge D250 Cummins automatic in the "Goodbye Kubota, Hello EarthForce" topic and a picture of my truck somewhere in there, I think. (Mine needed a clutch when I needed to go to SC to pick up the EF-5.)
But I see no reason why you couldn't easily put an EF-4 on a standard trailer and haul it on home behind your pickup, as long as the trailer and its brakes were up to the job.
If you don't want to, though, I'd be interested in discussing the possibility of my hauling it for you, depending on what it would cost you to ship it via traditional means. Like I said, though, I don't see why you couldn't do it, if you coudl find an appropriate trailer.
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
12in. Tooth Excavator Bucket (A64194)
12in. Tooth...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2014 Hyundai Sonata Hybrid Sedan (A61574)
2014 Hyundai...
2025 Ripper Tooth Excavator Attachment (A61572)
2025 Ripper Tooth...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
