Please help me solve 2 cub problems
   / Please help me solve 2 cub problems #11
The service manual says use a impact wrench or remove the top engine cover and use a flywheel holding tool. A impact has always done it for me. The old clutch may be stuck on the shaft and require you to use a puller to get it off. If you use a puller make sure you only grab on to the PTO pulley and not the drive belt pulley above it. When you reassemble use some anti-seize compound on the shaft and if you ever have to take it off again it will just slide right off.
Yup.. I just changed engines out on mine, had to remove the clutch with an impact wrench, the problem I had was removing the actual pulley from the crankshaft,
I wound up putting some heat to it to get ot off. but of course you are only changing the clutch so it will be easy enough:thumbsup:
Air Compressor (A57454)
Air Compressor...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A60429)
2024 CATERPILLAR...
2015 Dodge Charger Passenger Car, VIN # 2C3CDXAT4FH817483 (A57453)
2015 Dodge Charger...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
