Please help! Kioti CK20 won't start
   / Please help! Kioti CK20 won't start #11
I hope this helps.
  • Section 11 Electrical.pdf
  • Section 11 Electrical2.pdf
  • Section 11 Electrical3.pdf
   / Please help! Kioti CK20 won't start #12
The part number I found is 52794-4242-1 a quick google search showed a kioti parts place on line and then a link to ezgo golf carts, so this may be a fuse you can get at a auto parts store or mower repair shop, again never looked at mine don't know anymore about it :(
At least you know what the problem is now.
I REALLY hope that this is the problem. Autozone does have it in stock I think and I am hoping it's the source of the problem. Won't know until the morening but I will keep you all posted. Thanks so much for the help! I cannot believe that my owners manuals don't mention anything about this fuse!
   / Please help! Kioti CK20 won't start #14
Recommend you get a replacement plus a spare. That fuse may have blown for a reason, in which case you need to find the cause.
   / Please help! Kioti CK20 won't start #15
The previous owner of my Kioti called out dealer -- tractor would not start and could not find the problem. The PTO switch was turned on (kids had been playing in the barn) -- flip the PTO switch off, tractor started up fine...:ashamed:
   / Please help! Kioti CK20 won't start #16
Did the fuse work, or did the next fuse burn out?
The fuse fixed the tractor. You are a lifesaver! Thank you so muich!
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
2001  WABASH 53FT DRY VAN TRAILER (A57880)
2001 WABASH 53FT...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
202474 (A54757)
202474 (A54757)
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A56858)
2017 Freightliner...
2017 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A57880)
2017 VOLVO...
