Please educate yourself!
/ Please educate yourself!
The Smokey Mountains are in extreme eastern Tennessee, of which border and define North Carolina, as en entity of the Smokey Mountain National Park, being a part of the Appalachain Mountain chain.
Dale Hollow Lake is in northeastern middle Tennessee, roughly 150 miles away.
Just sayin'....... :D :D
I guess you are technically right but its still very hilly, especially the last 20 miles to the lake once of the main roads and onto secondary roads. All the lakes down there, Dale Hallow, Lake Cumberland, and Lake Norris are tough to drive to once off the main roads. I 75 is no treat either in Southern Kentucky and Northern Tennessee which is what we take most of the time. I 65 is not as bad but is really rough around Louisville.
Chris
Chris
/ Please educate yourself! #42
/ Please educate yourself! #43
I'm not totally sure what you're asking here. I've always special ordered all of my vehicles since the 60's and have found the prices to be better than "lot" vehicles. But then, I don't buy the "loaded" versions either which are usually what's on the lots. Often times with a little research, you can find a few extra items that aren't publicized that could make your vehicle a little closer fit to your needs. Personally, I wouldn't waste my time searching lots when you can write up your specs and hand them out to whomever wants to do business with you. I find that the truck managers respond very well. As to the "ordered" price compared to the "stock" price, there is still the price jump from 1/2 ton to 3/4 ton.
I have ordered a truck in the past but another option to ordering a truck is to use the internet to locate the truck you want then go to the dealer. Ford's website allows you to search by zip code and shows the window sticker for all trucks on each dealers lot. When I was shopping for my current truck at the end of the 09 model year I could not order an 09 becuase the factory had swithced to 10s. I wanted to save a few bucks and get the end of the year rebates. I had no loyality to a specific dealer.
/ Please educate yourself! #44
I asked a salesman what rear end was in a F250 once and he looked back at me with a dear in the headlights stare... he had no CLUE what I was asking..... we made an offer contingent on the answer since no one was around to check into it. It was a 3:55.. we didn't buy.
Don't you love it when you know more about the product than the sales person:)
/ Please educate yourself! #45
And I'll bet that the converter is unlocked most of the time with some of these economy axles, and maybe a fair amount of shifting too. You're also right on the debate issue.
Buy a diesel with an allison behind it and you wont have to worry much about converter unlocking.. :D
No, you just have to worry about the rest of the truck. Been there done that in 05 and never again. Longest 9 month of my life.
Chris
/ Please educate yourself! #47
Chris
Chris, Chris, Chris...You were starting to behave.:D
/ Please educate yourself! #48
Two years ago I looked at a used 2007 silverado vs. a new 2009. Both were 5.3's and both had the HD towing packages. The 2007 was rated for 7800 or so and the 2009 for 8500 IIRC. The 2007 was a 4 speed with 3.73 gears; 2009 a 6 speed with 3.42's.
Because of the changes in trans ratios, what I found was I would have 4 speeds in the 2009 covering the 3 speeds in the 2007; plus 5th spilt the difference between the old 3rd and 4th; and 6th was even taller than the old overdrive gear in the 4 speeder.
In some light towing situations you can tow in 5th and not 6th; but if you engage Tow/Haul, 6th gear is locked out - it's just too tall. Otherwise, with a heavy load, you're either in 3rd with the 4 speeder or in 4th with the 6 speeder. The 5.3 lacks the torque to pull the higher gears.
3.08 gears are at least 10% higher, that would really suck the life out of a 5.3, and would be the equivalent of the old 4-speeder with 3.42 gears, which also lacked tow power.
Definitely sounds to me like his truck is not setup to maximize towing........
BTW I bought the 2007, I don't tow that much and I think towing is limited more by the engine's torque than 4 speeds versus 6; so far I have been very happy with my truck, I pull a 23 foot boat with a total weight close to 6K and it handles it well here in MI where it's relatively flat; I'm sure it would work hard in the mountains through......
/ Please educate yourself! #49
I don't want to start a "my truck can beat your truck" post, but do want to respond to (brain55's) post as it refers to 1/2 ton trucks. I bought a 1/2 ton because it's my daily driver, I'm not a full time tower, and I want (reasonable) fuel mileage. I bought an '07 Toyota Tundra, 4X4, 5.7, 6 speed, 4:30 gear ratio with a tow package. Transmission ratio's are 1st-3.333 2nd-1.960 3rd-1.353 4th-1.00 5th-.728 and 6th-.588. This summer I towed a couple tractors to pulling events for a friend; 1, a 200 Farmall weighing 3500# and 2,a 960 Ford with pie weights and 1,000# of suitcase weights, weighing a little over 5,500# on a 16ft flat bed Bri-Mar tandem axle trailer. I'm estimating the trailer weighs somewhere around 3,500#. That's somewhere around 12,500# and the truck towed it easily. I wouldn't want to tow it cross-country, but I was totally surprised how easily the truck towed it, and yes, I kept it out of 6th gear. I routinely get 18+ mpg unloaded(in summer). So yes, in my opinion, and in opposition to "brain55", there is a place in the towing ranks for a 1/2 ton truck
Well heck, if that's the case I'm getting a 1/2 Toyota, because when I tow that much weight with my 1-ton duallie with an 8.1L, there is no way I would say it pulls it easily. It will pull it wherever you want to go, but you know you are pulling some weight. Let's see who stops first.
Brian
/ Please educate yourself! #50
Based on info provided in an earlier post, here's a look at the final mechanical advantage of the 4 spd with 3:73 or 3:42 compared with 6 spd and 3:08
First 2.48 x 3.73 = 9.2504
Second 1.48 x 3.73 = 5.5204
Third 1 x 3.73 = 3.73
Fourth 0.75 x 3.73 = 2.7975
First 2.48 x 3.42 = 8.4816
Second 1.48 x 3.42 = 5.0616
Third 1 x 3.42 = 3.42
Fourth 0.75 x 3.42 = 2.565
First 4.02 x 3.08 = 12.3816
Second 2.36 x 3.08 = 7.2688
Third 1.53 x 3.08 = 4.7124
Fourth 1.15 x 3.08 = 3.542
Fifth 0.85 x 3.08 = 2.618
Sixth 0.67 x 3.08 = 2.0636
/ Please educate yourself! #52
Brian
My statement "towed it easily" was not meant to imply it was loafing, but that it pulled it much easier than I had anticipated. As for the stopping, thats more a function of the trailer brakes/brake control adjustment than the truck :confused: While Maine and NewHampshire don't resemble Kansas, neither do they Colorado
/ Please educate yourself! #54
K7LN; Got your point reference the subjectivity(is that even a word)of opinions; my point was the area isn't pool table flat, but neither is it extremely mountainous. Having said that, I'm sure someone from NH will take me up on this. I should have said my area of travel is unlike either Kansas or Colorado :confused2:
/ Please educate yourself! #55
Guy's,
There is no 'right' answer here. Some of us tow every so often and need a truck that can handle what we're pulling around. The rest of the time it's a driver and a general hauler. Most of us 1/2 ton guys fall into this category. We just want a multi-purpose truck that can do everything pretty well, not one thing with perfection.
I could use a 1 ton dually diesel for some of the things I do, but I can't park it at work. Which means I have to have another vehicle that requires maintenance, insurance, plates and garage space. Not practical or financially feasable in any possible way.
If you tow 15,000# every day, a half ton isn't your thing. If you tow 8,000# every third weekend, a 1/2 ton is fine if it is set up properly, which really was the issue of this thread.
/ Please educate yourself! #56
The chevy 6 speed auto has a low first gear, they don't get deep rear ends. Most people don't like the 6 speed because they shift more. The convertor is locked a lot of the time to get fuel economy.
/ Please educate yourself! #57
Just stating there is no perfect answer.
Chris
No truer words have ever been spoken on this forum.
I'm kind of in the same boat as Patches and I suspect timswi. My half ton is kind of my daily driver. I have a take home vehicle from work, but my pickup is my only "pleasure" vehicle. I could probably afford an additional heavy duty one ton heavy duty pickup along with insurance, etc. however where I live currently I only have driveway space for 2 vehicles and I have to park my work vehicle on the street. I simply don't have space for another vehicle. Add to this the fact that my wife usually likes to ride in my truck on the weekends, etc. as she actually prefers being a passenger in my truck over her car. Part of why she likes my truck is because it is as spacious in the front and back seat areas as a Tahoe and rides like a car. The other main uses for a pickup for me are towing a snowmobile trailer and carrying a couple passengers and gear inside the warm cab, doing the same with ATV's and also occasionally picking up home improvement type stuff. I tow my tractor very infrequently and even though it doesn't handle the heavy load like a heavy duty diesel would my truck will tow the load. So given that towing heavy is seldom a concern for me, but ride comfort and ability to comfortably tow light loads and do it all economically are the primary reasons for ownership of a truck a half ton makes the most sense for me. A 3/4 ton or more truck won't ride as comfortably, gets horrible fuel economy in comparison and doesn't tow a snowmobile trailer any more capably than my half ton. So the only thing it does better is tow heavy loads, while being worse in the ride comfort category and fuel economy categories.
Now I own some land and am going to be building a new house and pole barn/ shop on it in the next year or two. I'll have space for more vehicles and by then the only debt we'll have is the mortgage on the new house (we're keeping our current house as a rental and should make money or at least break even on it). So I might look to keep my current truck and buy a used regular cab diesel 1 ton for heavy towing then when I have more space. I also may just replace my current truck with a new diesel crew cab and buy a BMW as an additional vehicle for general driving and better fuel economy as well as some more driving fun. In that case the pickup should ride well enough for my wife when the weather is bad, etc. but we'd probably drive the sedan the most. But by that time I won't be constrained by the space limitations that I have now so a compromise won't be necessary. I really can't wait to be able to start building...
/ Please educate yourself! #59
Pickups are just like tractors, each color has it's share of issues, etc. Really what it comes down to is, if we want one rig (either tractor or pickup) that does it all, then we have to compromise.
If we get one (either tractor or pickup) that is big enough to do some of the things we want to do that a smaller/lighter would not do, then we give up on the benefits of the smaller/lighter ones.
If we go the other way and get a smaller/lighter one, then it stresses things when we try and do the bigger jobs...
In a perfect world, we would be able to get the tractor or pickup that we wanted that would do everything we wanted and cost us nothing.
Back in the real world, I have way too many vehicles and need to get rid of some of them. We plan on trading Yukon XL in on 2011 3/4 Crew cab. Our 3 daughters are grown and we don't need the Yukon XL. We'll probably trade one or more of the other rigs in on a smaller rig for daily driver. Some of the projects are for sale.
You must be talking about that Dodge, eh?
No, 3500 dmax. My Dodge was actually a better more reliable truck but neither hold a candle to the Fords, Toyota, and Nissan I have owned.
Chris
2001 FORD SUPER DUTY F350 4x4 UTILITY TRUCK (A59912)
2001 FORD SUPER...
2013 Ford Taurus Sedan (A61574)
2013 Ford Taurus...
UNUSED WOLVERINE LL-12-78W-78" LAND LEVELER (A64281)
UNUSED WOLVERINE...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
