Plate for Hyd lines ??
/ Plate for Hyd lines ?? #1
DougM
Northeast Ohio
GC 2310
Has any one made a backing plate so that you could make connections to the back hoe on a 2310 easyier???
Pull back push forward with a small quick disconet is not that easy to do.
I now have 300 hrs on it and am very happy with it ........
DougM
/ Plate for Hyd lines ?? #2
DougM
You must have read my mind, I took off my backhoe for first time and was wishing for the same. I had to cut wire ties under chassis, took out some slack to get to connections easier. My fisher plow has quick connects mounted on plates in grill on my pickup. The fisher quick connects have a slot and c-clip to mount in hole on a plate. Other snowplow dealers and aftermarket should have them. plowkingl
/ Plate for Hyd lines ?? #3
Is this the kind of thing ya have in mind ??
That would look very nice on my 2310
DougM
/ Plate for Hyd lines ?? #5
This is intriguing, but I have 2 thoughts:
1. There is no place I can think of to mount the plate.
2. These lines have to be connected together when not attached to the BH,
further exacerbating problem 1. (A simple loop hose would have to be completely clear of the 3pt. hitch at all times.)
Perhaps a diverter valve of some sort could be used for problem 2?
/ Plate for Hyd lines ?? #6
I don't know if it will help any or not, but here are some pictures of the factory PBY bracket that MF uses on larger compacts. If there is any place to mount it, you might be able to order one to use. I'm sure that there would be some amount of modification that would have to be done.
/ Plate for Hyd lines ?? #7
I have installed a diverter to be used like that before. Here is how I did it and the type of valve that I used.
Surplus Center Item Detail
DougM
I think this would work all that would be need would be a 12in long hyd line to be used when the back hoe was NOT on the tractor ....
/ Plate for Hyd lines ?? #9
The fittings goin' though the plate are called bulkhead fittings.
Got 'em at a truck shop..........JJ.
/ Plate for Hyd lines ?? #10
I put a hook on the opposite side axle housing and loop the hoses around it and it keeps the hoses out of harm way. It cost me $1.50 for the hook from the hardware store.
Doug
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
NEW 2025 Trailer by Premiere Single Axle 12' Tilt  (A62679)
NEW 2025 Trailer...
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
Skid Steer Smooth Drum Roller (A65640)
Skid Steer Smooth...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
