Plastic Toolox Question ????
/ Plastic Toolox Question ???? #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I need to come up with a nice rugged tool box. I have always made them from wood. But I see there are a lot of nice weather proof plastic boxes available like this one. I stole the picture from rasorbackq's thread. Thank you. Hope you don't mind. A box like this would be better than one of my open boxes.
However, my experience with plastic stuff says that it probably won't last long outside in cold Vermont winters unless it is special plastic. How about these boxes. Can they stand some abuse in very cold weather w/o breaking or cracking ???? thanks.
gg
/ Plastic Toolox Question ???? #3
I have had a plastic toolbox mounted on my B7500 for about 10 years. It is nothing special, just a regular plastic tool box that I mounted to the loader frame. Much to my surprise it is still surviving.
/ Plastic Toolox Question ???? #4
My orange Homer Box from Home Depot lasted 3 years on my L3200 in Colorado. Was fine when the tractor sold with no noticeable UV degradation.
/ Plastic Toolox Question ???? #5
One more comment I should make ....
Be sure that the toolbox has metal latches like the one in your picture. Plastic latches just don't last long no matter what the conditions are!!
Well thanks for the replies. Pretty much 50/50. Think I'll put a small plastic box with hair pins, bushings, and small tools inside my wooden box full of heavy stuff and see what happens.
gg
/ Plastic Toolox Question ???? #9
Here is some photos of a "amo" box I added to carry choke chains in our UTV. Gosh, I do like these heavy duty, plastic boxes for jobs like this. Not sure if this is the size you need.
/ Plastic Toolox Question ???? #10
I use a large plastic Ammo box on my tractor. works very well, and weather tight!
/ Plastic Toolox Question ???? #11
As far as I can tell, nothing wrong with using plastic. It is lightweight, doesn't rust and many are waterproof. The plastic ammo cans seem to be the best choice. I mounted plastic tool boxes to both my tractors about 5 years ago. One has metal latches which have started to rust while the other is all plastic and the plastic latches are just as good as the day I put them on. I did have to do some water proofing on the solid plastic one due to lots of penetrations with handles and other things. A hot glue gun worked well for this. I do keep my tractors under a shed so most direct sunlight is blocked except for late afternoon (west side is open) but I don't know how well they would work in sub-zero conditions since it rarely gets below 15F here in winter.
/ Plastic Toolox Question ???? #12
I tried a plastic ammo box clone on my tractor, lasted about 4 months before shaking itself to pieces.
Switched to same size metal box, still doing well after 2+ years. Neither box leaked water on wet days.
/ Plastic Toolox Question ???? #13
I do not live in a cold part of the country. My tool box is a Stanley weatherproof type and is going on four hard years old. Still works great:
/ Plastic Toolox Question ???? #14
This plastic toolbox has been on for a couple years with no issues. Actually like it better than the metal one I had on my old tractor.
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
New/Unused Wolverine 84in Quick Attach Rock Bucket (A65583)
New/Unused...
Cattle Feeder (A65640)
Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
Warren Power...
4 Bottom Plow (A65640)
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
