Plastic front end fix.
/ Plastic front end fix. #1
dodge man
Super Star Member
West central Illinois
JD 2025R
/ Plastic front end fix. #2
I agree, should be the way it is assembled to begin with!! Once those brackets are in place, it is a breeze to take off and put back on!
Deano
/ Plastic front end fix. #3
Mine did that when I first got it home but when I brought it back (for some other reason) all they did was push down on the screens and it seemed to have tightened down. That was 3 years ago and I haven't had a problem since then. Of course that goes without saying I really haven't had a reason to remove it since then. Should I be removing is another question ???
I remove mine when I want to clean out the radiator well. You can pull the screen and the battery and it makes it easier to clean that area out.
/ Plastic front end fix. #5
I had this post several weeks ago. http://www.tractorbynet.com/forums/kubota-owning-operating/221750-plastic-front-end-fix.html
I bought the parts several weeks ago and just now got around to installing them. The plastic screen on my BX2350 fit like crap, it bowed out on the edges and fit poorly. The parts tie the side together and pull them in and make it fit much better. I don't know why they aren't factory items.
Glad to hear that you bought the kit we talked about a few months back. In the later model 50 series BX's, the screen already had the kit installed at factory. Not until Deano told me that his screen fit like crap did we realize that Kubota made a change between when his was built versus when mine was built.
