Plasma Cutters anyone?
/ Plasma Cutters anyone? #21
Don what you will like about the Henrob is you can weld cast iron easily. They recommend using piston rings for filler rod.
I like it because you can braze without flux.
I haven't tried cutting with it. Heck, I've got three chop saws at the shop, an oxy acetylene cutting rig, two plasma torches, three sawsalls, two portabands, and that's just for cutting steel.
It works okay on aluminum. But tig works better.
/ Plasma Cutters anyone? #22
Before anyone buys a Henrob check out the regulator requirements. I believe it operates on a much lower pressure and volume than a regular torch. Not sure but I think some of the lower end regulators don't go down this far.
Could be wrong, I was one other time/w3tcompact/icons/smile.gif
/ Plasma Cutters anyone? #23
You're right. They operate at four psi oxygen and acetylene. And it is set at the regulator and not at the torch.
/ Plasma Cutters anyone? #24
wroughtn harv-
Thanks for the tips on cutting! I printed out your comments so I can nail them up on the barn wall where they will be handy. Plan to buy a set of torches in a week or so. I will also check out the regulators for use with the Henrob (4 psi) which I will probably buy some time in the future. Picked up a new 14" chop saw last night at the local Home Depot on sale. Now I can start to cut up some scrap to practice arc welding on before I work on anything good.
/ Plasma Cutters anyone? #25
I was sure that the prices were there somewhere but I did not search hard enough. It is still a little pricey but cheap compared to some of the things it replaces. I may have to get one now though. I am a tool junkie and now that I have been reminded that I never got one of these I will not be able to sleep until I do. I wanted a plasma cutter too but did not work on modern cars and did not really have a use for one and that has not changed.
/ Plasma Cutters anyone? #26
This is out of my Haynes Welding Manual. The gas (compressed air) is heated to a plasma state, so it conducts electricity, the gas actually makes the cutting arc.
/ Plasma Cutters anyone? #27
Thanks Ed, doing research on this type of unit as it appears to have most of what I would need. The problem I have is I get excited about a neat unit and then someone else pops up with another option.
PJ
/ Plasma Cutters anyone? #28
There is a guy on the forum over at www.industrycommunity.com that has a he11 of a good deal on a used one...$45,000 or so new, he'll let it go for $16,995! ;)
/ Plasma Cutters anyone? #29
On the subject of Plasma cutters, I have a Spectrum Thunder, which is a Miller product. It runs on 120v/18A and has a built in air compressor. It seems to work very well up to about 3/16". In theory, it does up to 3/8", but at about 1/4", I find it to be very slow. Thats the point where I switch to a cutting torch.
It should be noted that most of the 'home' sized machines you will see are really great for doing thin materials. My Thunder does an outstanding job on thin materials that a cutting torch would make a mess of. It will also cut aluminium, stainless, brass, and copper, which a cutting torch can't handle.
The plasma cutter also gives you quite a bit more control since you are not as concerned with overheating the material. The key to the cutting torch is the heat and the speed of travel. With a plasma cutter, heat isn't as critical.
I think the bottom line is if you are planning on sheetmetal or thin plate work, a plasma cutter is a great tool. If you are thinking about > 1/4"-3/8", you either need a larger plasma cutter or a torch.
Kevin
/ Plasma Cutters anyone? #30
The name Plazma Cutter came from the narrow jet of air plazma that actually does the work.
The first generation used a hydrogen gas and another gas for the plazma beam, where the hydrogen performed about the same thermal enhancing function it does in an electric arc furnace. As time went on, manufacturers developed a superior machine that was able to use compressed air instead of purified gasses for the beam.
Trust me on this, first generation machines were a real BI%(# to operate, and costs were HIGH. The current generation of Plazma is a walk in the park, sort of like comparing a square wave TIG to a 30 year old TIG.
/ Plasma Cutters anyone? #31
Thanks Franz, was wondering how they came up with that name. From reading other post on the Plasma cutter I would need to go with a larger unit as I would be cutting and welding 1/8 to 3/8 material.
PJ
/ Plasma Cutters anyone? #32
Kevin-
I am in the process of learning coppersmithing (copper sculptures), and had considered buying a plasma torch to do fine detail cutting of copper sheets. I've never seen a plasma torch in operation, so can you give me an idea of how small a hole you can cut in copper sheet with a Miller like you have? Thanks.
Ken
/ Plasma Cutters anyone? #33
Ken, copper sheet will cut the same as steel or stainless, or aluminum with Plazma. Thickness capacity on copper will be somewhat less than steel, because copper dissipates heat better than steel.
When the dealer demoed my Thermaldynamics, he sliced thru a sandwich of steel, stainless, copper and aluminum, and the cut didn't vary between materials that I could tell.
I'm presuming you are talking about thin copper sheet, .050 thickness for the sake of argument, and on that, the cut would probably be around .030 wide with my machine.
Large capacity machines do have a wider cut.
You can also gouge with Plazma, but that might not be applicable on thin sheet copper.
As far as piercing, my machine would pierce .050 sheet with a hole diameter of around .030. There might be some spalling on the back side when piercing copper, can't really say without trying it.
My advice would be to take a piece of your sheet goods to a legitimate welding supplier, and have them demonstrate. That way you'll also get a feel for how the gun fits your hand, and the work you will be doing with the machine.
/ Plasma Cutters anyone? #34
Here in Norte Tejas some of the Lincoln dealers have set up rooms where they have all their stuff available for demonstrations.
Probably the most important thing to keep in mind with your plasma torch is you're going to need consumables. This is one of those purchases where you need to go in understanding that your dealer is going to be your best friend whether you want him/her to be or not. So buying at a box store like Tractor Supply, Sams, Home Depot, Lowes, might save you in the short term but it has teeth that will tear you a new one down the road.
I've got Esab and Miller torches. Their parts are available area wide and for me that is important.
This is also the time of year when you can get a good deal from the dealer because the model changes are coming in.
Another thing that blows most folks away is they walk in and pick up an item in a welding supply and almost choke at the price. They just left one of the box stores and it was a third less. So they assume everything in the store is priced accordingly. I never pay list on anything at my welding supply. My minimum discount is twenty percent and usually it's more than that.
Of course the box stores will set you up and clean your clock just as well.
One time (I might be slow but I'm not stopped) I had misjudged an order from a fence wholesaler on some parts. These parts in total run me seventy to eighty cents a unit. On a Saturday the wholesaler was closed and I ran short. I needed a hundred of the units. I went to Lowes and Home Depot. After much crying, hammering, begging, and general snot slinging fit throwing I got HD down to two dollars a unit. If I'd paid their asking price it would have been about three dollars a unit.
I haven't done that again. Like I said, I might be slow, but I'm not stopped.
Do look at the big picture when shopping for a plasma torch. You might get a heckuva deal on the basic torch but if you can't get consumables it's like wanting to start a family and keep your wife a virgin too. You're going to have to consider adopting er adapting as a way of life.
/ Plasma Cutters anyone? #35
There is an Astro brand plasma cutter laying in the electritians shop at my work. One of the sparkys has it there to try and fix for a friend of his. Turns out its made by some outfit in Italy and some consumables from Daytonamig might fit it. The cutter itself has an electrical problem with no schematics available. Harv is right on the name brand stuff.
/ Plasma Cutters anyone? #36
I am late LOL You have already bought the toy. I have a Hypertherm 900 Plasma Cutter Will cut 1 inch steel starting from the edge or will pierce 3/4 this is hand cutting But I mainly run it on a Plasmacam table cutting 1/8 or less sheet steel or Stainless steel for My sideline business Wall art,entrance signs etc.
It is great Always remember to subtract about 20% from what the manf. claims for there products mine is supposed to cut 1 1/8 steel but let me tell you I have cut 1 inch with it and it is a lot harder than oxy/act but for less than 1/2 I go with plasma above 1/2 oxy/act fires up. On 16 gauge or less plasma with a drag tip cut just about as fast as you can move your hand. I really like clamping a straight edge and cutting against it Cutting a 4x8 sheet in half with a oxy/act is work for me but plasma take about half the time it takes to unroll the hoses and set the regs for oxy/act. and no tip changes for different metal thickness just turn the dial for more or less amps. Each has it's uses and as has been said before Neither replaces the other Main two things are clean/dry air clean/dry air clean/dry air and clean metal
/ Plasma Cutters anyone? #37
I've got a set of torches and 2 plasma cutters. I rarely use the torches but that is probably because they take a little more skill than the plasma. So don't count out the learning curve. With plasma you only have to learn what to set the amperage to and how fast to move the torch.
/ Plasma Cutters anyone? #38
I bought a Hypertherm 600 about a month ago and have been very happy with it. I have cut several pieces of 2 x 1/2 mild steel bar stock with no problem. There is a little slag on the backside of the cut compared to thinner pieces, but that comes off easily with a few taps of chipping hammer.
The plasma is definitely easier for me to use than an O/A torch.
What materials do you use for templates. I have tried cardboard, hardboard and wood. These all work fine, but there is always some scorching. I need something that will last a little longer and be flexible. I am going to need to notch several pipes as I continue work on my fencing and also other projects that will be using pipe.
/ Plasma Cutters anyone? #39
For your pipe there is a product called "sure cut". Some of the welding suppliers carry them. They are clamp on template out of heavy steel that you just follow with your torch.
There is quite a selection. I have one that is for two and seven eighths to cut ninety and forty five degrees. Another to do a saddle and an orange peel. The orange peel is used for making the end into a cap.
In two and three eights I have not only those but also another that is for saddling two and three eighths to two and seven eighths at one end and I believe three and a half at the other.
You can make your own by going up one size of pipe over what you're working with. Make a template and keep trying it until it makes the cut you want. Then cut it lengthwise. Across this cut weld a butt hinge. Then cut it again lengthwise a hundred and eighty degrees over from you first cut.
I usually weld a tab on each side and then use vice grips to hold it closed but you can make a spring over clamp is you're so inclined.
On repetitive cuts with the plasma I usually make a template out of quarter inch steel. The template is made along the principles of one made for routering patterns. It's the width from the center of the cutting tip to it's edge bigger all around.
Then it's a simple matter of laying the template on the material, starting the cut and then just keeping the torch vertical and against the template.
For doing circles you can buy a circle cutting kit. They are all right but I have fallen back to using a circle cutter an old weldor made for me for a cutting torch. It works just fine without all the clutter the circle cutter kits get into.
Another thing I do with the plasma is just draw out what I want with soapstone. Then I set my hood to shade five and get after it.
/ Plasma Cutters anyone? #40
I always enjoy your posts wroughtn_harv.
I have always wondered how the rounded ends were made that I had seen on fencing. I had always assumed it was something cast and added on. I wish I had known about this when I was working on the corner posts and gate posts.
I did a search on google and found a document describing the orange peel at http://www.advancement.cnet.navy.mil/products/web-pdf/ tramans/bookchunks/14251_ch3.pdf. A lot of other neat information in that document as well. After you cut the orange peel, do you hammer it into place cold or does it need to be heated first.
I have seen the templates at my welding supplier, but never looked at them too closely. It looked like some were made of leather. When I was working on a corner posts, I worked out the equation for the saddle cut , cadded it up in Intellicad and cut the template out of a section of round duct work. The template was good, but freehanding along a soapstone line left alot to be desired. O/A or plasma is very unforgiveing of an unsteady hand.
On using metal for a template, I thought I had read some place there could be problems with double arcing in the torch and a reduction of consumable life. So I was trying to stick with non conducting templates. I also expect some templates I want to make may not be available at a welding supply, so I will need to custom make them.
JOHN DEERE 8400R TRACTOR (A64280)
JOHN DEERE 8400R...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
(3) 3 1/2" X 36" HYD CYLINDERS (A64280)
(3) 3 1/2" X 36"...
