Plasma cutter
/ Plasma cutter #31
Got a order for over a TTL of items. I do have 10 more months to make all of them. Have 1/4 of them make. I have a 5'x10' table with a 3400 cfm fan under it. I have a number of online shops and ship my metal signs worldwide. jack707, the compressor cost 1K. On a water table, if the water is close enough to catch all the dust, then it is so close it will short out the torch. Far enough away not to short out the torch, you will only catch app 1/2 the dust.
Cabinhollow many thanks! Very interesting appreciate the info.
/ Plasma cutter #32
If you do a lot of cutting, or painting. A cooler, after cooler, and a Motor Guard filter system are very good things to add to your shop.
I have installed the large black iron "U's" with drains at the bottom of each. The Franzinator installed before it catches 80 - 90% of the water relative to the "U's". I find it the cheapest reliable way to get rid of most of the water.
Ken
iDrive TDS-2010H...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
