Plasma cutter question?
/ Plasma cutter question? #41
BHD. What did you order in the way of sheet metal shear? Us tool guys gotta know these things.
I ordered a guillotine shear, that was listed as 39" but when it came in it will only cut 30 -32"" which was a disappointment, the over all length was about 39" (in my opinion a misleading description),
it was about $260.00 with the shipping, similar to this one, Manual Guillotine Shear 32" x 16 Gauge Sheet Metal Plate Cutting Cutter w/ Stand | eBay and then I added a table, to the left of the blade, and added straight edge, and a clamping system, and a stop for repeated cuts, And remade the stand so one could extend the cut if needed, something similar to this, Heavy Duty Fully Cast Iron Manual Arm Guillotine Shears
some pictures of the shear and the add on's
/ Plasma cutter question? #44
Nice job with the table and add ones BHD!
Are you happy with it’s performance? Capacity as claimed?
a few of the other things I have been workin on, remodeled the stand for the bead roller, as I am making a fence for it and the stand was in the way, a rolling shear, made the stand for it, used a lod 16.5 rim, a vice stand, this is my welding vice, if I need to I can make tabs to bolt it to the floor, but don't know where I think it would be best location, the welding table out a plate of 1" by 24" steel,
a set of shelves, on one wall,
DCP_6777.JPGDCP_6776.JPGDCP_6775.JPGDCP_6774.JPGDCP_6773.JPGDCP_6772.JPGDCP_6771.JPGDCP_6770.JPGDCP_6778.JPG
really have not had a chance to use it yet, so as to how I like it I really can't say, I am sure as with most of this type of tools the capacity is over rated, "at least for ease of use"
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
2018 GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
2018 GENERAC...
2009 CHEVROLET IMPALA 4 DOOR CAR (A66091)
2009 CHEVROLET...
2017 Ford F-250 Ext. Cab Knapheide Service Truck (A66736)
2017 Ford F-250...
2019 Kenworth T880 Tri-Axle Dump Truck (A61573)
2019 Kenworth T880...
2018 SKYJACK  SJ843TH (A67714)
2018 SKYJACK...
