Plasma Cutter Project,, WhAtSyOuRgUeSs ??
   / Plasma Cutter Project,, WhAtSyOuRgUeSs ?? #11
mash cooker?
OK, Part "B" of this project started out as a 55 gallon barrel, with one end removed.
The barrel was sitting outside, filled with water. As the barrel froze, the ice expanded, and "domed" the closed end.
I cut a hole in the dome that is the size of a 5 gallon bucket lid.
Notice the color of the barrel is light rust color, and yellow.
Here is a pic of the oil tank, with the Part"B" 55 gallon drum on top,
It is now ready to burn the half dozen LARGE stumps I have in one field.
These are big stumps, the trees were over 30" at 5 feet high,
The stumps are 50 to 60 inches across at ground level.
This is a fun way to get rid of stumps in the winter, and it gets rid of EVERY bit of brush, and branches that falls off of my other trees.
Yard cleanup, and some exercise, at the same time! Win-WIN! WOOT!!
I filled the oil tank with brush, and branches, logs up to 6 inches in diameter,
It took WAY more than I expected, I had to make a second trip to the brush pile for more wood.
A quart of old motor oil was added, a HF propane "Weed Burner" was aimed under the oil tank,
the fire was blazing in about 3 minutes,,
Flames are shooting out of the hole in the 55 gallon drum dome, at least 3 feet high.
This stump burner has been burning over 8 hours today, I went back and added more wood one time.
I had a ladder next to a trailer, to be able to get high enough to drop wood into the top of the barrel.
The top of the barrel is right at 8 feet high, I get pretty good draft,, the draft sucks in air at the bottom, incinerating the stump.
Notice how black the intense heat has turned the rust on the 55 gallon barrel,
the light rust color and yellow paint was GONE about 2 minutes after the flames started to exit the "chimney".
   / Plasma Cutter Project,, WhAtSyOuRgUeSs ?? #15
I built a similar stump burner from an old oil tank. Cut a hinged door on the side to refuel. Loops on top to move with FEL. Felt safer burning for days. The chimney really helps.
I will add a door, and move loops,, I mostly want to try it,,
Adding more fuel from a step ladder is a little tricky,,, :ROFLMAO:
I had never burned stumps with anything bigger than a 55 gallon drum.
   / Plasma Cutter Project,, WhAtSyOuRgUeSs ?? #17
Often soak the stump in used oil while covered with burner. Adding wood till full and staging extra by for several 12 hour burns. After several burns the stump can smolder for days. Once used an old atv tire…burned hot! Most of stumps as big or bigger diameter than the tank. Tank lasted about two years and about twenty stumps. Cut your door high as the tank slowly rust/crumbles at the ground. Be aware fire can follow roots beyond the tank. My rock imbedded ground and stump size would be expensive to grind.
Stumps cut close to ground take forever to rot. Very hard to dig out with backhoe. Cut higher and covered with leaves and dirt will rot quicker.
I usually burn stumps during nicer weather,,
but, it was almost 70 degrees, so, I had to burn the stumps,,
The burning went on perfectly as long as it was warm,, the burned stump smoldered over night, and all the next day.
THEN,, it turned cold,, below 30 degrees,,
no matter how much wood I tossed in the barrel, as soon as the wood was burned, the smoldering stopped.
I guess the smoldering does not like being fed cold air,,,
   / Plasma Cutter Project,, WhAtSyOuRgUeSs ?? #20
Good to know that the burn solution works. We have had dozens of dead Ash trees from the dreaded Ash Borer in WI. I realize you don't always have the luxury of tipping a tree due to space surrounding it but I have loosened the roots on many dead/dying trees with this bad boy then pushed the tree over "before" cutting. The weight of the tree pulls the stump out with it. After it tips, I cut it in half and have the whole thing on pile in about 30 minutes. 20" to 24" dia. trees no problem and NO leftover stumps!
Deere 50D (A60462)
Deere 50D (A60462)
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2012 Ford F-250 4x4 Pickup Truck (A60460)
2012 Ford F-250...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
UNKNOWN  500BBL FRAC TANK (A58214)
UNKNOWN 500BBL...
