Planting grass seed
   / Planting grass seed #1
JMAC
SE Kansas
JD 4310, MFWD,E HYDRO
I am on a long term project of replanting maybe 10 acres of my property with several different types of grass seeds which some could be rather pricey and I want to do a better job than to just broadcast the seed. What are some good seed planters that a individual could buy? I know rental would be much cheaper but there are no rental places in my area that has anything like this for rent and really not anyplace that I have found that seems to know much about this type of equipment.
JMAC
   / Planting grass seed #2
The two options I can think of right off are drop spreaders or a small drill. The former will cost considerably less to own and operate but you will probably have to roll the bed after spreading. Both put seed right where you want it though. Other options would be to contract the work out or lease a small unit.
   / Planting grass seed #3
You might contact your local County Extension Office. They have equipment for rent.
   / Planting grass seed #4
I'll second what Billy said. They have seeders and sprayers at my local office. They are not near as much as a all rents center would charge either.
   / Planting grass seed #5
Wow, must be nice. Are rates more or less than what you could get thru an equipment dealer?
   / Planting grass seed #6
Your cheapest option is to work the ground up, broadcast then roll. If you want a seeder, then Brillion makes a good one. I also heard that Frontier (John deeres label) is marketing a nice one. If you use a seeder, then I recommend 2 passes, 90 degrees to each other. 1 pass will do the job, but the grass will come up in rows and IMHO looks crappy. Adding the second pass fills this in and doesn't take nearly as long to fill in and look good. You'll use twice as much seed, but it is worth it.
   / Planting grass seed #7
I am working on a similar project and am trying this method. First I work the area with a harrow rake, tines down, spead the seed with a broadcast spreader, then rework with the harrow rake tines up.
Don't know how well it will work yet, but it has to be better than just throwing seed.
Let us know what you wind up doing.
   / Planting grass seed #9
An FYI for future reference - many of us who review the discussion board from time-to-time from work can't hit eBay - it's not allowed through most corporate firewalls.
Bill
Ken,
That is a interesting piece of equipment, I am interested in the 6 ft. one. I have e-mailed for a freight quote on your site.
Thanks for your reply.
   / Planting grass seed #11
Maybe this will work for those without ebay access. It's in interesting piece of equipment, I would be curious to know how well it actually works.
   / Planting grass seed #12
It seems to me that the Yardmaker would work well for lawn start-up. As an aerator, it's better than nothing but you would be compacting soil more so than a good core aerator. As an over-seeder, it would seem to be of marginal help in getting seed-to-soil contact. I could be wrong. /forums/images/graemlins/ooo.gif
I've looked at them and they are well-built.
Just my take, here....I've always used a large tine de-thatcher to shallowly incorporate seed after broadcast for both new areas and overseeding. A drag harrow/chain harrow after broadcasting works for primary seeding, too.
   / Planting grass seed #15
Isn't most primary seeders nothing more than a double cultipacker with a seed box inbetween?
Ken, can you add a seedbox to that cultipacker?
   / Planting grass seed #16
I have done projects like that on two occassions. But only smaller. I probably did 1/2 acres. However my best luck was to work the soil up good and then broadcast seed with my Herdseeder. When done I would drag the seed in once or twice over. This gets the seed in the ground about a 1/2 inch or so. Then about a week after I would then broadcast a good fetilizer over it that had a lot of nitrogen in it. This method actually worked better than the seed that was drilled in by our landscaping guy. Everything he did I had to go back and work over and seed it myself. Do this in the fall or spring when you have cooler temperatures. Fall is best because the ground is still warm at night.
murph
UNUSED FUTURE 30" MINI EXCAVATOR PALLET FORKS (A60432)
UNUSED FUTURE 30"...
2022 CATERPILLAR 299D3 XE SKID STEER (A60429)
2022 CATERPILLAR...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A59904)
2003 VOLVO VNL...
CATERPILLAR 926M WHEEL LOADER (A60429)
CATERPILLAR 926M...
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
SWICT 66" SKID STEER BUCKET (A60430)
SWICT 66" SKID...
