Plans wanted for simple well house.
   / Plans wanted for simple well house. #1
ArmyofOne
Ft. Bragg, North carolina
Hey guys and gals,
Got a small project that needs to get done here before the cold sets in. I need a simple and cost effective Well house that will keep my pump from freezing but leaves me access to hook up water lines for the horses water if needed.
I'm trying to make something simple that will try and stay around a $100 budget. Any ideas? or perhaps known plans for something similiar that can be found on the net?
Thanks,
ArmyofOne
   / Plans wanted for simple well house. #3
What is your minimum size to contain all of the components (well pipe riser, any pumps, pressure tank (s))?
With a budget of $100, how about essentially making a dog house without the door? You could make a small hinged door (say 6" x 6") just big enough to reach and turn on/off a hose bib mounted just inside the wall. You could also insulate the inside as needed. The small dog house would also enable you to completely lift and remove everything for easy access later.
   / Plans wanted for simple well house. #4
Tell us a little more... my well house in VA is mostly underground with a flat roof with no insulation and I put in an outlet to run a 100 watt light bulb for heat but it never really even needs that. I assume your pump is on the ground and you want to build a stucture around it? If you make something 4 feet by 4 feet, it could be cheap but will it be big enough?
   / Plans wanted for simple well house. #5
How big does it have to be? Will an ice chest, upside down cover it? What about a large plastic tub? You can line it with one inch foam from Hope Depot for pretty cheap.
What about cement blocks on the sides and some thick foam for a cover?
I don't think you can build something out of wood and make it weather proof so that it doesn't rot away on you, for $100.
Eddie
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A53843)
TOOTHED BUCKET...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
20X30 ALL-STEEL CARPORT W/ ENCLOSED SIDEWALLS (A53843)
20X30 ALL-STEEL...
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
