Planning stages for remotes for stump grinder
   / Planning stages for remotes for stump grinder #1
lovedgor
Etowah, Tn.
Kubota M6040
After my first post about rear remotes, I have been considering using diverter valves from the FEL Quick Connects to control the stump grinder. Does anyone think this would be a bad idea?
   / Planning stages for remotes for stump grinder #2
If your FEL valve has regen, I would bungee the valve lever to the tilt up side.
Why do you not want to use the rear remotes?
I was just thinking it would be easier and cheaper to use the valve already installed. I will use the regen to return the grinding wheel back to start position. I have one rear remote already, and will use it for top link. If I use the diverter plan, I can use it for a grapple also, and not have to install both a valve and diverter.
   / Planning stages for remotes for stump grinder #4
20' Inline Feed Bunk (A50515)
20' Inline Feed...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52128)
Kubota SVL65-2...
Ingersol Rand 175 Air Compressor (A50774)
Ingersol Rand 175...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2015 Dodge Charger AWD Sedan (A50324)
2015 Dodge Charger...
