Pit Cart Project Started
/ Pit Cart Project Started #1
Waldon52
Platinum Member
Michigan , usa
John Deere
For many years I have wanted a Pit Cart type portable workbench I could move from the workshop to the front garage or to the rear shed or to the backyard and have all my tools with me. Even my welders and plasma cutter, grinders and hand held band saw. I have 40 feet of 220V extension cord and 40 feet of 110V extension cord . It will also have 12 outlets for easy plug in tools. Yesterday I mounted a old vise and one of my drill presses to a old metal table I had not used in 3 years. Today I mounted the Lincoln welder and a tool box to the bottom shelf. Also a small wire welder to the back of the cart. I also layed out the width of the axles for the 8 tires it will ride on. This cart will pass through my narrow shop doors being pulled by hand and then it will have a hitch for my garden tractor to pull it anywhere in the yard . Tomorrow I will design the support for the front mounted plasma cutter. I'll keep you posted as I make more progress on it. I am very excited to build this . I have spent hours walking back and forth getting tools for dozens of projects. The duel wheels will make this heavy load much more stable when pulling it in the back yard on soft ground. It will be so handy to have all my tools so close wherever I am working. pitcart.jpg
/ Pit Cart Project Started #2
I know how you feel about walking back and forth ! A couple of suggestions:
Use a Reelcraft hose reel for your electrics and keep them low. (maybe even an air line reel). This is to keep it from tipping over. I'd worry that it could get top heavy and make a mess or worse.
Lockable drawer to prevent low use tools from walking away. I also like lockable 4 corner casters because I can never get my cart into that perfect position. That conflicts with towing, but there are 'ways'. Battery powered tools work best for me because cords and hoses come at me and wrap themselves around my legs. I need extra battery chargers and batteries on board for making that 1, single final cut that always is needed and the battery went T/U.
Beverage holder and fire extinguisher became necessary for me after a repair job on my baler in the field. Chaff caught on fire while I was under the hood. Ooops.
I'm sure there a few more suggestions coming, make provisions for dual axles and heavy duty springs to accommodate all of them !
/ Pit Cart Project Started #3
Man, you're definitely gonna enjoy "more workie less walkie" with that, it'll be interesting to see how far it goes -
I'd considered something similar with a "freebie" steel table, 3'x5', heavy angle frame and 3/8" steel top - I was gonna put a 3PH on one side, got QH's on both small tractors. But before THAT happened, the freebie "morphed" into something else :rolleyes:
http://www.tractorbynet.com/forums/welding/386590-welding-table-build-6.html#post4889466
Still really useful to me, but now I'll hafta start over with the mobile work table idea... Steve
I will be careful not to put anything else above the table because being top heavy could be a real problem on uneven ground with that narrow wheelbase. The cords are a pain but I am going to try a couple ideas to keep it all looking clean without all the cords and cables everywhere when not being used . Beverage holder and fire extinquisher a must. I bought a nice little compact Milwaulkee radio yesterday for it too. Mostly I'm organizing everything I already had on one cart. Everything in my shop is already on small wheels , so this is just a fun project . It may rarely leave the workshop . But the days I work in the back yard on something big that wont fit in the garage or shop it will be great. I also have 40 ft of air hose for the plasma cutter. I have the air retractable reels and the electric retractable reels in my workshop now. They are very handy. I already put one on this by the drill press. Very excited about this little project.
Today I cut out the first wheel radius and the first panel section for the lower storage area. Also worked on the two end shelves that will support the plasma cutter and the handheld bandsaw. Tomorrow I'll work on the other back corner and second rear fender panel. I am very excited even at the early stages to have everything so handy. It will be rare it leaves the shop or the front garage. But if it does then it will be pulled with the garden tractor. pitcart fender.jpg
Todays welding cart progress I made a few brackets to hang sanders, nibblers and 2 air drills on the rear. I also finished up some upside down welding and boxes in the lower center axle opening. Finished securing the center welder and the tool box to the main frame. A little red paint and it almost looks like it all belongs together. I'm already enjoying the 12 new outlets with 6 on each end. The front design will include brackets for a few more hanging tools. The rear will be set up so all the electric cords and air hoses are nice and neat. Very fun little project.Painted rear pit cart.jpg
/ Pit Cart Project Started #7
Nicely thought out. Your Lincoln buzz box and Craftman tool box blend right in. ? though- how do you keep your drawers on the tool box from opening. Or is that not a worry. Normally the lid is closed to keep them shut.
Either way it looks great. :thumbsup:
Thanks, I'll attach a stopper for the toolbox drawers if it leaves the workshop . Today I cut out the parts for the front axle assembly. I also built the matching faceplates it will all pivot on. I welded the lower pin to the axle . The upper tube has the faceplace now welded on it for smooth steering . Next I will extend the front of the cart and attach the front pivot tube with plenty of support . This fifth wheel hitch type design was easy and inexpensive. I went this route because of the duel wheels or I would have built the traditional spindle and tie rod setup.steering.jpg
/ Pit Cart Project Started #10
Do you ever think you're going to want it road worthy? Meaning towing with truck or whatever down the road. Toolbox on wheels, neighbors might be calling you up?
No , the cart wont ever leave the yard , but once in a while it will be very handy in the backyard. You can see in the photo a car cant fit in my small workshop . The big door is only 5.5 ft
wide. Just a nice little organizational project I never took the time to build for the small workshop. The next photo I post next week the front should be done. Then I will spend a day on the rear getting it all organized with nice neat cords and air hoses all hanging up and organized. Once you make a place for everything it is easy to put it back each day in just a few minutes.
/ Pit Cart Project Started #12
Great idea. I'm constantly walking back and forth from the tractor to my workbench getting the "latest" tool that I hope will get it done.
Today I cut out metal for the front steering support frame. Got it all welded together and now I can roll the cart with two fingers. It is going to move very nice with those 8 larger tires.front frame.jpg
/ Pit Cart Project Started #14
Do you still think you will need the garden tractor to move around the yard?
/ Pit Cart Project Started #15
Glad to see that your back in the shop. Didn't see anything from you in a long while and we can't lose the talent that you have
I think I can move it around by hand in the backyard. Yes, it seems good to be back in the shop.
Welding Cart Front Progress- Today I got the front fenders attached, finished extending the front frame and building front shelves. Painted more red on the new metal. Very happy how the front steering works so easy. Once I get the pivot pin and the face plates greased it should turn perfect.frontpaintedred.jpg
Portable Workbench Progress - Todays photo shows the rear of the cart nice and neat with all the cords and cables organized. Next I will move to the table top where I will build stands for a retractable worklight, a retractable multiple electric cord, and a retractable air hose. Also a stand for a radio. But I will keep everything above the table for maximum use of the small table surface.cords.jpg
Here are the last four items to be added to the cart. This afternoon I finished the supports and the shelves and got them painted. Tomorrow I will get everything mounted and be done with the cart. retractables.jpg
/ Pit Cart Project Started #20
Waldon, you do some very nice work. Everything done with perfection.:thumbsup:
2016 HAMM H7i SMOOTH DRUM ROLLER (A60429)
2016 HAMM H7i...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
UNUSED CFG INDUSTRIAL MH12RX MINI EXCAVATOR (A62130)
UNUSED CFG...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
