Piston for ford naa
/ Piston for ford naa #1
gmk5150
mitsubishi
Im looking for teflon seal for lift cylnder..1954 forn naa..pistion is 2.5 inche dia
i cant where to buy tefon or neoprene..i wrecked 2 leather ones...any assist where to purchase
/ Piston for ford naa #2
Last time this came up I could no longer find the rubber backup washer, only the leather one. I suspect it may have been discontinued for some reason.
When you tried to install the leather ones did you soak them in boiling water before making the attempt? I have been lucky and each leather backup washer I have installed using the the hot soak method worked fine.
They say there is teflon thats way better.. im unable to find them..yes i soaked it...but cut them trying force in cylinder
/ Piston for ford naa #4
I agree the with it being better than the leather but if they no longer make them... for whatever reason then leather is your only choice. Did you use a ring compressor when installing the piston? I use a well lubed (oil dripping) engine ring compressor to successfully squeeze the rings in without damage.
I will try that thank u kindly
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
2001 Ford F-150 4x4 Pickup Truck (A61568)
2001 Ford F-150...
Volvo EC220EL (A60462)
PALLET OF APPROX (10) SCISSOR LIFT CONTROLLERS (A62131)
PALLET OF APPROX...
2019 Bobcat MT85 (A61166)
2019 Bobcat MT85...
2015 Dodge Journey SXT SUV (A61569)
2015 Dodge Journey...
