Piston for ford naa
/ Piston for ford naa #1
gmk5150
Member
mitsubishi
Im looking for teflon seal for lift cylnder..1954 forn naa..pistion is 2.5 inche dia
i cant where to buy tefon or neoprene..i wrecked 2 leather ones...any assist where to purchase
/ Piston for ford naa #2
Last time this came up I could no longer find the rubber backup washer, only the leather one. I suspect it may have been discontinued for some reason.
When you tried to install the leather ones did you soak them in boiling water before making the attempt? I have been lucky and each leather backup washer I have installed using the the hot soak method worked fine.
They say there is teflon thats way better.. im unable to find them..yes i soaked it...but cut them trying force in cylinder
/ Piston for ford naa #4
I agree the with it being better than the leather but if they no longer make them... for whatever reason then leather is your only choice. Did you use a ring compressor when installing the piston? I use a well lubed (oil dripping) engine ring compressor to successfully squeeze the rings in without damage.
I will try that thank u kindly
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
Water Tank (A61570)
Water Tank (A61570)
2014 FORD F-350 SERVICE VAN (A62130)
2014 FORD F-350...
1985 Ford Ltl9000 Tender Truck (A61307)
1985 Ford Ltl9000...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
