Piston for ford naa
   / Piston for ford naa #1
gmk5150
mitsubishi
Im looking for teflon seal for lift cylnder..1954 forn naa..pistion is 2.5 inche dia
i cant where to buy tefon or neoprene..i wrecked 2 leather ones...any assist where to purchase
   / Piston for ford naa #2
Last time this came up I could no longer find the rubber backup washer, only the leather one. I suspect it may have been discontinued for some reason.
When you tried to install the leather ones did you soak them in boiling water before making the attempt? I have been lucky and each leather backup washer I have installed using the the hot soak method worked fine.
They say there is teflon thats way better.. im unable to find them..yes i soaked it...but cut them trying force in cylinder
   / Piston for ford naa #4
I agree the with it being better than the leather but if they no longer make them... for whatever reason then leather is your only choice. Did you use a ring compressor when installing the piston? I use a well lubed (oil dripping) engine ring compressor to successfully squeeze the rings in without damage.
I will try that thank u kindly
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
**SALE ORDER ANNOUNCEMENT** (A51242)
**SALE ORDER...
2006 Peterbilt 379 T/A Wet Kit Sleeper Cab Truck Tractor (A49461)
2006 Peterbilt 379...
