Pins for Front End Loader
/ Pins for Front End Loader #1
Philip_L
Folsom, LA
Kubota L185 2WD
Guys
I am designing a FEL in Solidworks for my little Kubota, and was stealing ideas off of a bobcat. I noticed they use the pins (see attached Solidworks jpeg) for the pivot mounts for the cylinders. Any idea what these little gems are called and where one can get them? I may also try to use Large Bolts if I can find some with grease fittings and grease channels already cut in them.
Thanks
/ Pins for Front End Loader #2
I made some pins for my FEL mounted plow before I made it work with a quick coupler. Purchased them from TSC. They are 1" in diameter. Drilled them for a grease fitting and put a hole that put grease in center of cylinder end. Since the fitting was behind blade and out of the way. I did not need to counter bore pin to recess grease fitting like your illustration shows. In the attached picture it is only being used to match up to my quick coupler. Quick coupler does not move so it does not need grease. The pins come in 6" and 4" lengths. Hope this helps.
/ Pins for Front End Loader #3
Ron,
Did you attach a three point blade to your front quick coupler and spin it around? I was thinking about doing that to plow snow this winter. If you did how does it work for you?
Thanks in advance.
Dan
/ Pins for Front End Loader #5
<font color="blue"> Did you attach a three point blade to your front quick coupler and spin it around? </font>
No I did not. Its a Curtis blade. You can see it in my photos here on TBN. Click Here
There is also a picture of a rake that I mounted on the FEL. My Rear Blade is way to heavy to mount on the FEL. See picture is my photos.
I do not want to steal someone else's thread. Here is a link to a thread the blade and it's use. Click Here
John Deere 5093E (A64126)
John Deere 5093E...
1979 Log Trailer MODEL JCV040 40ft Long 65000 GVWR (A62679)
1979 Log Trailer...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
3pt Peanut Wagon QA Hitch (A64127)
3pt Peanut Wagon...
INOP/NON-RUNNING 1957 B61 Mack (A65563)
INOP/NON-RUNNING...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
