Pillow block question
/ Pillow block question #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
What is the difference between a standard duty and a medium duty? Princess Auto now sells a med ium duty block . Searched the net for the answer but only catalogs sales appear.
/ Pillow block question #3
Likely different load ratings. Did you check the specs?
/ Pillow block question #6
/ Pillow block question #7
I found only a difference between standard and heavy. It was the webbing, how the outside steel was constructed around the bearing. Thicker all the way around with larger "Fins" that meshed to the bolting tabs. The tabs were solid (Not hollow).
Both for a 1" bearing from Princess Auto Princess Auto
Standard duty
Attributes & Specifications
Inside Diameter 1 in.
Max. Radial (Downward) Load 3,000 lb
Max. Axial (Thrust) Load 1,500 lb
1 in. Standard Duty Pillow Block Bearing Assembly | Princess Auto
Medium duty
Max. Radial (Downward) Load 3,150 lb
Max. Axial (Thrust) Load 1,575 lb
1 in. Medium Duty Pillow Block Bearing Assembly | Princess Auto
Guess that answers that . Thanks. BHD
Guess I will be sticking with the standard .
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2016 JCB 3CX 4x4 Loader Backhoe (A68183)
2016 JCB 3CX 4x4...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
2014 ALLMAND MAXI-HEAT PORTABLE HEATER / GENERATOR UNIT (A67714)
2014 ALLMAND...
2018 FORD F-250 SUPER DUTY LARIAT (A67714)
2018 FORD F-250...
2017 CATERPILLAR 926M WHEEL LOADER (A65056)
2017 CATERPILLAR...
