Pillow block question
/ Pillow block question #1
rasorbackq
Springfield Nova Scotia Canada
Branson 4720
What is the difference between a standard duty and a medium duty? Princess Auto now sells a med ium duty block . Searched the net for the answer but only catalogs sales appear.
/ Pillow block question #3
Likely different load ratings. Did you check the specs?
/ Pillow block question #6
/ Pillow block question #7
I found only a difference between standard and heavy. It was the webbing, how the outside steel was constructed around the bearing. Thicker all the way around with larger "Fins" that meshed to the bolting tabs. The tabs were solid (Not hollow).
Both for a 1" bearing from Princess Auto Princess Auto
Standard duty
Attributes & Specifications
Inside Diameter 1 in.
Max. Radial (Downward) Load 3,000 lb
Max. Axial (Thrust) Load 1,500 lb
1 in. Standard Duty Pillow Block Bearing Assembly | Princess Auto
Medium duty
Max. Radial (Downward) Load 3,150 lb
Max. Axial (Thrust) Load 1,575 lb
1 in. Medium Duty Pillow Block Bearing Assembly | Princess Auto
Guess that answers that . Thanks. BHD
Guess I will be sticking with the standard .
Flail Mower
Flail Mower
2017 Mack Semi (A64047)
2017 Mack Semi...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A66736)
2016 Chevrolet...
2005 Acura RSX Coupe (A66738)
2005 Acura RSX...
2012 MERTZ FRAC MANIFOLD TRAILER (A67714)
2012 MERTZ FRAC...
Hyundai GP Bucket (A68134)
Hyundai GP Bucket...
