PICTURES ONLY thread
/ PICTURES ONLY thread #461
"Were gonna need a bigger boat!"
A boat full of tourists got to snap the picture of lifetime while floating down Australia痴 Adalaide river; giant saltwater crocodile leaped out of the water right next to the boat.
Wags you can have your river creatures; I'll stick with our snapping turtles and leatherbacks.
Ooops I saw pictures only and posted without reading the rules! But can you just imagine cruizing along in your pontoon boat about to go to sleep and OMG!
BTW, photoshopped?
/ PICTURES ONLY thread #463
Just curious Rick;
Do you leave the tooth bar on all the time?
I love the looks of them and I know the tractor would dig dirt and such much better. I plan to get one at some point.:thumbsup:
Yes, I installed my PTB shortly after I got my previous LS XR4046HC in late 2014. When I traded it in on new LS XR4155 HC I just kept my bucket since it already had the PTB and weld on hooks installed. New owner of my XR4046HC got a new bucket.
I also swapped out my highly modified grill guard as well.
PTB has never been off bucket since installed. It digs better and back drags better too.
/ PICTURES ONLY thread #464
Out of curiosity, Rick, did you weld your hooks directly to the bucket, or did you add a base plate for reinforcement? I bought hooks for my bucket, but haven't attached them yet, and was wondering if I even needed to add any support.
Pic from last year, just to comply with the thread rules. ;)
/ PICTURES ONLY thread #465
Paul, Did you buy bolt or weld on hooks?
I bought weld on for mine. I wasn't sure how thick the top was so I welded on a piece of 2x2x1/8
" angle to my bucket top then welded the hooks to that.
/ PICTURES ONLY thread #466
I bought weld on hooks, George. I've seen other guys here talk about welding on a support plate, then welding the hook to that. Angle iron would clearly work, too. Is it necessary?
/ PICTURES ONLY thread #467
I used weld on .... since I had them. One in middle and two more on ends. I didn’t do anything to strengthen the top of bucket because I don’t try to lift anything heavy with bucket. Most of the time my grapple is on the tractor so, any heavy lifting is done with grapple. I think heaviest I’ve lifted with bucket is the front of my Zero Turn for blade replacement.
/ PICTURES ONLY thread #468
Paul,
The top of the bucket appears to be rectangle tubing that I believe is 1/8" thick (I was not sure of that). I didn't want to weld to just the bucket if that was true for fear of ripping the hooks and a chunk of metal out of the bucket on a heavy lift so I added an extra 1/8" angle to mine. If you don't plan on a heavy lift or pull on the hooks then welding to the bucket directly will be fine.
/ PICTURES ONLY thread #469
Paul,
Thanks, gents. Much appreciated. I don't anticipate any seriously heavy lifting, and any heavy pulling is done with the draw bar.
/ PICTURES ONLY thread #471
Thanks for the reply Rick,
When I finally get around to getting a PTB and Hooks for the bucket I'll post some pictures, even though mine is the wrong color for this thread.:laughing:
PJS,
I was wondering the same thing about a backing plate for the hooks. I think I'll add a plate, I'll sleep better at night.:)
/ PICTURES ONLY thread #472
Logging with the Bobcat E42, Food plot work with the 4066R
/ PICTURES ONLY thread #474
My cheap top. Limbs and branches took care of the lights
/ PICTURES ONLY thread #475
I bought my small farm when I retired from the Army in 2010 and originally had 10 acres and my little Kubota B2320 was adequate for what I was doing back then but as we have expanded to 21 acres (plus some leased land) it was clear I needed to step up. So a couple months ago I found a screaming deal on an XG3140 with shuttle shift and I traded up.
Unfortunately we have had record breaking cold weather, snow and ice but it has still gotten a workout.
/ PICTURES ONLY thread #476
Got mine out of the barn for the first time this winter. Was in the 50s on Sunday, so I got the leaves cleaned out of the ditch by the road and carried them back to the burn pile in the pasture.
/ PICTURES ONLY thread #479
My lovely babe, learning to run the back hoe while trenching:
/ PICTURES ONLY thread #480
No pics of the tractor working right now, but spent all of yesterday cleaning the tractor, and actually put a coat of spray wax on it:D
1991 FREIGHTLINER FLA-89 T/A SLEEPER TRUCK TRACTOR (CABOVER) (A67148)
1991 FREIGHTLINER...
Gehl RS6-34 (A64119)
2012 Ford Escape SUV (A64557)
2012 Ford Escape...
JOHN DEERE 5055E TRACTOR (A65054)
JOHN DEERE 5055E...
7066CFL (A64553)
7066CFL (A64553)
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
