screamin400
Platinum Member
- Joined
- Aug 1, 2015
- Messages
- 750
- Location
- Lee Center NY
- Tractor
- 2016 Mahindra 2538, 2016 Mahindra 2655, 2017 CaseIH 75C, 2021 CaseIH 110c., 2020 Kubota svl 65-2, 2022 Kubota svl 75-2, Kubota svl75-3, Kubota M6
In the snow industry we make sure we get into the tractors with dry shoes and do not get out. I have a broom in my barn I sweep my feet with. When that snow melts it will fog your windows. This may not be as much in yours as our industry. I also run a 12v fan on my back window when icing up on the outside. Fan on the tractor is full bore all the time. Dries my nose out after a few hours of work.Got 6" last night so I got to put the T254, Bercomac blower and cab into action this morning. Neighbors were impressed that I took their end of driveway stuff and threw it across the road into the wind. With the cab, the snow didn't end up in my face. It's not heated but you do get a little heat off the engine that takes the edge off the cold. Was pleasantly surprised that the plastic windows didn't ice up. They seem far enough away from my body where my breath doesn't end up on the plastic, plus there is plenty of ventilation. The blowing snow does not have direct access to you but you do get a little from underneath and from the vents in the sides of the top. So far I'm quite tickled with the setup, just need to fix the loose nut behind the steering wheel so that it gets more efficient.
