So, what's the verdict? Are you happy with your purchase? Did it's performance meet your expectations?
Yep. It Really did do Well.
kind of a long post , but here goes
As posted earlier I left the other end of the loop driveway alone since Before all these storms piled up. Wanted to see if blowing going forward and not pre cutting with the bucket was possible with deep multiple storm snow.
Pretty sure there is 2 feet there.
It took most of the 50 or so HP at the PTO but expected that with the large 27 inch diameter impeller.
My tractor is rated at 2000 RPM and PTO speed is 1900 RPM, don't generally rev it that high- bush hogging or tilling, so getting the largest impellor was part of the plan to make the most of hopefully running a bit under 540 and taking advantage of the fan tip speed.
I made it all the way through WITHOUT stopping then turned around backed up (3 point lifts this unit nice and high) and repeated going back up the drive . Had I tried that with the bucket It would have taken at least twice as long if not 3 times.
The tractor would have made it several feet and then would have had to bucket off to the side.
I still need to use the FEL to clear the plowed in part of the drive from the hi way department but that is what the bucket is still good for. Not sure that I would use a rear facing blower for that either lots of ice and compressed chunks it would have to shred.
I even made some trails for the wild turkeys.
Several things that impressed me with the WIFO Inverted so far
Impeller to housing clearance is Tight, less than a quarter inch.
I Got a bit more width. With the built in "wings" the outside width is actually about 87 inches.
Snow does not go over the top of the back of the blower, even the time i did bog the engine the high back plate seems to keep it in the box and the perforated top cover acts as a coarse rock/debris shield.
If in too high of gear in the really deep stuff the load can start to bog the engine , but that is where an Inverted or front mount shines with a tractor like this one that came with only a high or low reverse gear.
With 6 forward gears there Is a gear that will get the job done effectively.
A bit extra weight as well- if the decal on the side is correct it says 1275 lb. Actually needed to add a couple extra pounds of air to the rear tires to reduce side wall bulge,
Lots of steel
Nice welds and Good powder coat Job.
The entire Blower drive is Really quiet.
Checked the 90 degree box ( a Comer) no heat was detectable after the deep and heavy snow test wasn't expecting any either, Nice tight lash with very little drivetrain play.
It had the correct, at least for my remotes Quick connectors.
I still need to contact the dealer and see if there is a longer stroke cylinder for the deflector. For now I made a steel extension
(not in the pic below) and it gave enough range for "almost" all needs but a longer cylinder would give Full range.
Would I recommend a WIFO Blower as a well built, well priced, quality unit, with only one day of initial use.?
Yeah I would. Very Impressed.
I Think Inverted blowers in general are eventually going to be the dominant style here in the US "eventually"
