Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #4,991
I am glad that I waited a little longer before taking the snow blower off the tractor. We got about 12 inches of heavy white snow over night.Just came in from blowing and it was a nightmare as there is no frost under the snow and had to watch not to rip up the driveway etc which was hard to do. Blew a shear pin the first one this year which is good.
   / Pictures of your snow weapons #4,992
Well i too pulled off all snow equipment , cleaned them, touch up paint to stop rust and stored them away. Even if it does snow again, the ground is too sloppy to use the equipment. We have had 5 days low 60s. Still have 2 ft of snow in yatd, but going fast.
   / Pictures of your snow weapons #4,993
Took the chains off my ATV and tractor but I have to wait for some more snow to melt to store everything away. Why is removing things always easier than putting them on?:confused3:
   / Pictures of your snow weapons #4,994
you got that right. It takes me over 3 hours to chain up the tractor, but 30 min to remove the chains. The hydraulic system snd blower add another 2 hours for installation, but since i always have to clean and touch up paint on them, it takes just as long to remove. Then i have to remove all summer items from barn and place all winter items in their place. This is about a 4 hour ordeal. Only good thing is it allows me to clean up the building and reorganize everything. Its amazing how many “so thats where that went” times i find.
   / Pictures of your snow weapons #4,995
I wasnt going to temp fate by removing tractor chains this soon, but muddy ground is being torn up by chains. I pulled them off this morning. I guess i should be ready for 30” of snow tonight:cool2:
   / Pictures of your snow weapons #4,996
Glad to see an honest post. A couple of dealers tried to convince me a front mounted blower was an easy on/off. When none of them actually demonstrated how "quick and easy" it was, I suspected the worst.
Will be using a SSQA front mounted angle blade and maybe adding a 3 pt blower.
   / Pictures of your snow weapons #4,997
i have to first mount the 60 pound hydraulic pump....which is a pain in the butt cause the 2 fixed hoses make it hard to install. Then i mount the tank which holds 25 gal of oil. Then i have to route 2 - 1” hydraulic hoses down and around axles to the front. I had to manufacture several brackets myself to hold hoses inplace. Then i have to mount control wand and route electrical wires to front. Once this is done, it only takes a few minutes to swap between bucket, front plow or front blower. But initial set up is half a day. Maneuvering cold, large and stiff hydraulic hoses sucks. But it all is worth it when i have to move the 120” of snow we received this year.
   / Pictures of your snow weapons #4,998
Dropped the chains off the tractors and swapped out the studded snows from my pickup and my wife's car for the summer tires,
so now it's time for a big April storm.
   / Pictures of your snow weapons #4,999
Ok so I do run a Landscaping business but here are our snow machines IMG_20190212_094706.jpegIMG_20190119_152907.jpegIMG_20190110_152855.jpegIMG_20180226_190320.jpeg
   / Pictures of your snow weapons #5,000
That's what I'm thinking too!
2015 Ford Transit 250 Cargo Van (A50323)
2015 Ford Transit...
2007 International 7600 Tri-Axle Dump Truck (A50323)
2007 International...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A52748)
GALAXY - SET OF...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2003 Mercedes-Benz SLK Coupe (A50324)
2003 Mercedes-Benz...
