Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,101
Amarsh, I take it off all the time, literally takes 3 minutes. My question is for all the snowblower owners out there. I have a possible lucknow 72 inch snowblower I might get a friend to look at..as I won't be home for a while. The owner says its a shear pin. What do most think of shear pins as opposed to the slip clutch. I'd prefer the slip clutch, but Do most think a shear pin is alright. Said the blower wasn't used much at all, its $2100 Canadian. I think their getting close to $4000 if new, around these parts anyway, but then I noticed other prices under $3000 elsewhere in Canada. There is also a 62 inche Kubota snowblower also..not sure if that has a clutch or not. My tractor is 5 feet wide, so 60 inches there abouts...
I have a 6' Lucknow, and it is a very heavy duty and well built blower. I have only broken one shear bolt in the 6 years I have had it, and I was back up and running in 5 minutes. As a State Side consumer, Lucknow is a royal pain to get parts for though.
   / Pictures of your snow weapons #3,102
Just got a new John Deere 1025R with a 54" blower and loader
   / Pictures of your snow weapons #3,103
Today I got the dirt weapon uninstalled
Then I had a naked little tractor for a couple of hours
And finally I got the new snow weapon attached . Pretty pumped for some snow :D
Taking the backhoe off for the first time went fairly well . Hopefully getting it back on will go smooth as well !
That looks like a real nice snowblower! You'll have to report back after your first big snow. I'm not familiar with your backhoe mounting system, but I was a little nervous the first time I went to reinstall my hoe, and for the first few months I went out of my way to minimize taking it on and off. Turns out it is pretty easy, and these days I don't even think about it. I bet you will get real fast at doing yours.
   / Pictures of your snow weapons #3,104
I had a Bobcat ssqa complete assy. hanging around and made it to fit a 3 pt hitch. Mostly just because I could with just a little work & some steel. I have a bunch of skidsteer attachments and got to thinking about a plow on each end might speed things up some. Not sure I'll take it on my plowing "route" but I hitched it up today just to see how it looked and the added length.
   / Pictures of your snow weapons #3,105
Very nice..Ive been thinking and wondering about a three point that had the ssqa on it...
   / Pictures of your snow weapons #3,106
My snow weapons are positioned in the barn for a quick exit ... 1480682248080.jpg
   / Pictures of your snow weapons #3,107
My latest purchase is a 30 inch plow. I think Mrs-tiller has enough ballast for traction, I just hope she doesn't step off the edge causing a rollover.
snow plow.jpe
   / Pictures of your snow weapons #3,109
Heavy made blower. Their alright. Is it pretty quick to replace the pin? Carry a few extras and just replace where is? I was wondering if I could buy a slip clutch and convert
There are two shear pins (1/4" Grade 2 bolts) on my Pronovost and both are easy to replace. I carry two small zippered tool bags under the seat. One general pins, and tools. The other has bolts, Nylock nuts, a 7/16" box wrench and a small ratchet with a 7/16" socket. The bolts and nuts are in ziplok sandwich bags to make them easier to locate. I break 8-10 per season. Replacing a bolt is so quick I usually don't bother putting my coat on when I get out to do one.
   / Pictures of your snow weapons #3,110
chim
Nice rig.
When done blowing snow, what is your routine for cleaning off the equipment? Stored without heat in shed, waiting for next storm, or in a heated area?
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2019 KOMATSU  D65 PXI 18 (A52472)
2019 KOMATSU D65...
2014 Ford Escape (A50323)
2014 Ford Escape...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
