Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #1,261
Here is something I found quickly. Take this idea and modify to keep the lower shelf and then add a bar to hang the weights on. Along with the shelf bolted to your hitch flange and bolt to the sides. You would be set.
Chris
   / Pictures of your snow weapons #1,262
Chris
Here is a photo of the weights, they are fairly large, about 18" tall so I have to make sure they will be mounted high enough as to not drag the ground.
Thanks for the suggestion & photos, now all I have to do is find someone with a welder.
John
   / Pictures of your snow weapons #1,263
John
Sounds like the perfect excuse to become "someone with a welder". Christmas is just around the corner.
   / Pictures of your snow weapons #1,264
cshultz, looks great it should really help.
   / Pictures of your snow weapons #1,266
ttstraw said:
All ready to go minus the chains.....<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=290773"/>
DUDE! How much weight do you HAVE on that beeotch!? Will you even need chains? AND you have 4WD, you will be unstoppable!
   / Pictures of your snow weapons #1,267
Now that you all make me look bad! Guess I better find time to take the FEL off my Deere and put on the snow plow! Had to use the FEL with last weeks snow.
   / Pictures of your snow weapons #1,268
There are 34 pavers in the box at ~17.5lbs each, so right at 600ish lbs plus loaded rears. Last year with the weight in the box I only needed the front chains but it was a very light winter snow wise here.
   / Pictures of your snow weapons #1,269
The more weight the better!!!!! Plain and simple.
Chris
   / Pictures of your snow weapons #1,270
Mac 3200 Chainsaw (A57454)
Mac 3200 Chainsaw...
2020 Steiner 450 Slope Mower (A57453)
2020 Steiner 450...
2022 Horizon (A55973)
LOT: Better Built Heavy Duty Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Better Built...
PALLET OF 11 BARBED WIRE ROLLS (A58216)
PALLET OF 11...
2000 Ford F-450 Dump Truck, VIN # 1FDXW46F5YEB20130 (A57453)
2000 Ford F-450...
