Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #1,261
Here is something I found quickly. Take this idea and modify to keep the lower shelf and then add a bar to hang the weights on. Along with the shelf bolted to your hitch flange and bolt to the sides. You would be set.
Chris
   / Pictures of your snow weapons #1,262
Chris
Here is a photo of the weights, they are fairly large, about 18" tall so I have to make sure they will be mounted high enough as to not drag the ground.
Thanks for the suggestion & photos, now all I have to do is find someone with a welder.
John
   / Pictures of your snow weapons #1,263
John
Sounds like the perfect excuse to become "someone with a welder". Christmas is just around the corner.
   / Pictures of your snow weapons #1,264
cshultz, looks great it should really help.
   / Pictures of your snow weapons #1,266
ttstraw said:
All ready to go minus the chains.....<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=290773"/>
DUDE! How much weight do you HAVE on that beeotch!? Will you even need chains? AND you have 4WD, you will be unstoppable!
   / Pictures of your snow weapons #1,267
Now that you all make me look bad! Guess I better find time to take the FEL off my Deere and put on the snow plow! Had to use the FEL with last weeks snow.
   / Pictures of your snow weapons #1,268
There are 34 pavers in the box at ~17.5lbs each, so right at 600ish lbs plus loaded rears. Last year with the weight in the box I only needed the front chains but it was a very light winter snow wise here.
   / Pictures of your snow weapons #1,269
The more weight the better!!!!! Plain and simple.
Chris
   / Pictures of your snow weapons #1,270
CFG Industry QK16R Mini Excavator (A57149)
CFG Industry QK16R...
2015 Wacker Neuson G50 38kW Towable Diesel Generator (A56857)
2015 Wacker Neuson...
Unused IRTPL 10,000lb Two Post Car Lift (A55272)
Unused IRTPL...
VOLVO EC460CL EXCAVATOR (A58216)
VOLVO EC460CL...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
1988 FONTAINE TRAILER CO. 50 STEP DECK LOADER TRAILER (A58214)
1988 FONTAINE...
