Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #6,691
Always surprised by the ones that can handle snow plowing without chains. Then I remember that not everyone has steep hills to handle.
   / Pictures of your snow weapons #6,692
You know I have turf tires on my Kubota l-245dt and got chains with it and never had to put them on. I can go through over a foot of snow plowing and it doesn't slip at all.
My first CUT was a JD 955. I reworked a set of semi truck chains to fit and ended up never using/needing them.
With my present 4410 I've only ever wished for chains once since 2004. It was a really wet snow and it turned to ice as soon as the tires put pressure on the snow. No traction at all!
   / Pictures of your snow weapons #6,693
Where i live, snow always turn to ice. Always have freeze, than thaw, then freeze then snow. Without chains my tractor plows sideways on flat ground.
   / Pictures of your snow weapons #6,694
Same here - snow turns to ice. Don't even need a thaw freeze cycle. Just continually driving over snow that doesn't melt off hard packs it into ice.
gg
   / Pictures of your snow weapons #6,695
Same as well...plowing with tractor rear tire chains only have to be ready to counter steer going around curve.
   / Pictures of your snow weapons #6,696
Very hilly here. My kitchen windows actually look out onto a ski slope. I guess my driveway is relatively flat, by comparison to some, but even my neighbors with more hilly drives seem to be doing them without chains. All are asphalt, though, which is probably key. If I were on gravel, I'd probably be running chains.
   / Pictures of your snow weapons #6,697
A Few, Newer Truck now though.
   / Pictures of your snow weapons #6,698
Cool Pic. Which body of water is that ?
   / Pictures of your snow weapons #6,699
No pictures, because I don't know how.
TYM 674 with cab. 72" inverted snow blower and a 72" snow pusher.
We'll see how the R1's do this winter.
   / Pictures of your snow weapons #6,700
Rainy Lake, Ontario side not Minnesota side
2171 (A58376)
2171 (A58376)
2023 RTVXG-850 SideKick (A56438)
2023 RTVXG-850...
JCB 3CX 14HFCA BACKHOE (A52709)
JCB 3CX 14HFCA...
2826 (A58376)
2826 (A58376)
Unused 20x20 Carport With 10' Half Enclosed Side Walls (A55272)
Unused 20x20...
2014 FORD F-350 CAB & CHASSIS (A58214)
2014 FORD F-350...
