Pickup HVAC Problem
/ Pickup HVAC Problem #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I have a 2015 Chevy Silverado 2500 pickup with 44,000 miles on it. 6.0 liter V8. 3/4 ton. Bought new. Pretty solid truck.
Currently, it does not matter what HVAC button I push to direct the air flow inside the cab - the air only comes out of the front ducts regardless. Sometimes I really want the defrost - to blow air onto the windshield.
Any ideas why I am now unable to defrost as intended? The air-flow buttons still light-up when pushed, but make a liar out of me when I tell Wifey the defroster is on when it is not.
TIA
Yooper Dave
Sounds like an actuator might have went bad. I've replaced a few on my older GM trucks.
How difficult and costly to replace? Is this a common issue? Thanks!
/ Pickup HVAC Problem #5
I’ve replaced blend door actuators on two different vehicles, a Dodge Challenger and a Chevy Impala. The Impala was easier, I went in through the glove box but not exaggerating when I say I spent about twenty minutes taking one bolt out and back in.
The challenger as you can see required an awkward angle.
/ Pickup HVAC Problem #6
yea do it once, you learn very quickly to simply pull the seat out. generally 4 bolts and a couple connectors.
/ Pickup HVAC Problem #7
I thought about pulling the seat but it didn’t look that easy to me. I might have been worried about the air bags too.
/ Pickup HVAC Problem #8
generally requires you to disconnect the battery, there are airbag sensors in most seats now
/ Pickup HVAC Problem #9
There’s an actual side airbag in mine in that picture. Probably not really that scary.
/ Pickup HVAC Problem #10
It depends which one is not working...I think the defrost/face/floor might be under the dash on the older models. I'm not sure about your year. They usually go out slowly instead of like a switch though.. I'm surprised.
/ Pickup HVAC Problem #11
You might try checking the fuses as stated earlier. Maybe even disconnecting the battery to see if it resets and starts working even for a little bit.
/ Pickup HVAC Problem #12
There is often a YouTube video for your specific vehicle that can be a lot of help in figuring which actuator is out and help in replacing them.
/ Pickup HVAC Problem #13
Curious if you looked into the issue more, or found the solution? Thanks
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A65563)
2004 International...
John Deere Gator (A62613)
John Deere Gator...
JOHN DEERE 5100 TRACTOR (A63291)
JOHN DEERE 5100...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
1988 Kenworth W900 Day Cab (A62613)
1988 Kenworth W900...
1990 Ford 3930 Tractor (A65579)
1990 Ford 3930...
