Pickup HVAC Problem
/ Pickup HVAC Problem #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I have a 2015 Chevy Silverado 2500 pickup with 44,000 miles on it. 6.0 liter V8. 3/4 ton. Bought new. Pretty solid truck.
Currently, it does not matter what HVAC button I push to direct the air flow inside the cab - the air only comes out of the front ducts regardless. Sometimes I really want the defrost - to blow air onto the windshield.
Any ideas why I am now unable to defrost as intended? The air-flow buttons still light-up when pushed, but make a liar out of me when I tell Wifey the defroster is on when it is not.
TIA
Yooper Dave
Sounds like an actuator might have went bad. I've replaced a few on my older GM trucks.
How difficult and costly to replace? Is this a common issue? Thanks!
/ Pickup HVAC Problem #5
I’ve replaced blend door actuators on two different vehicles, a Dodge Challenger and a Chevy Impala. The Impala was easier, I went in through the glove box but not exaggerating when I say I spent about twenty minutes taking one bolt out and back in.
The challenger as you can see required an awkward angle.
/ Pickup HVAC Problem #6
yea do it once, you learn very quickly to simply pull the seat out. generally 4 bolts and a couple connectors.
/ Pickup HVAC Problem #7
I thought about pulling the seat but it didn’t look that easy to me. I might have been worried about the air bags too.
/ Pickup HVAC Problem #8
generally requires you to disconnect the battery, there are airbag sensors in most seats now
/ Pickup HVAC Problem #9
There’s an actual side airbag in mine in that picture. Probably not really that scary.
/ Pickup HVAC Problem #10
It depends which one is not working...I think the defrost/face/floor might be under the dash on the older models. I'm not sure about your year. They usually go out slowly instead of like a switch though.. I'm surprised.
/ Pickup HVAC Problem #11
You might try checking the fuses as stated earlier. Maybe even disconnecting the battery to see if it resets and starts working even for a little bit.
/ Pickup HVAC Problem #12
There is often a YouTube video for your specific vehicle that can be a lot of help in figuring which actuator is out and help in replacing them.
/ Pickup HVAC Problem #13
Curious if you looked into the issue more, or found the solution? Thanks
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Greenworks Commercial 82V Utility Vehicle 500 CAMO Model: U500SC - DEMO UNIT (A63689)
Greenworks...
NEW HOLLAND C227 SKID STEER (A64279)
NEW HOLLAND C227...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
2021 TAKEUCHI TL12R2 SKID STEER (A64279)
2021 TAKEUCHI...
17601CFL (A59228)
17601CFL (A59228)
