picking up leafs in fall with X-Series tractor
   / picking up leafs in fall with X-Series tractor
Yup, after rethinking the whole issue I agree and think slightly wider tires schould be the first step in ordert to be able to drive over the wet lawn at all. I will take some measurements, but as a guestimate i think some added 2 or 3 inches would be Maximum before colliding with the mower deck. That would mean 26X14-12 or max 26X15-12... I just have to find rims and tires of this size somewhere.
regarding leaf-pick-up technique, I am not shure yet. I will first get the deeer mulch kit with the plastic thingy and 3 mulching blades and try that. I currently use gator G6 blades with side discharge and they do not mulch much without any plug at the chute. Then I will look into further alternatives.
   / picking up leafs in fall with X-Series tractor #12
I had a mulching kit on my JD. It was great on leaves, but didn't like it for grass. Putting it on and off each season was way too much work. It might work for you OK. If you mulch the leaves, you may need to apply lime to counteract the acid. Winter fertilizer is also a good idea, but fertilizer has gotten so expensive.
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
INGERSOLL RAND DD-16 SMOOTH DOUBLE DRUM ROLLER (A51242)
INGERSOLL RAND...
2018 ISUZU FTR 24FT BOX TRUCK (A51222)
2018 ISUZU FTR...
2021 Doosan DX350LC-5 Hydraulic Excavator (A49346)
2021 Doosan...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
