picking up leafs in fall with X-Series tractor
   / picking up leafs in fall with X-Series tractor
Yup, after rethinking the whole issue I agree and think slightly wider tires schould be the first step in ordert to be able to drive over the wet lawn at all. I will take some measurements, but as a guestimate i think some added 2 or 3 inches would be Maximum before colliding with the mower deck. That would mean 26X14-12 or max 26X15-12... I just have to find rims and tires of this size somewhere.
regarding leaf-pick-up technique, I am not shure yet. I will first get the deeer mulch kit with the plastic thingy and 3 mulching blades and try that. I currently use gator G6 blades with side discharge and they do not mulch much without any plug at the chute. Then I will look into further alternatives.
   / picking up leafs in fall with X-Series tractor #12
I had a mulching kit on my JD. It was great on leaves, but didn't like it for grass. Putting it on and off each season was way too much work. It might work for you OK. If you mulch the leaves, you may need to apply lime to counteract the acid. Winter fertilizer is also a good idea, but fertilizer has gotten so expensive.
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
Kinze 840 Grain Cart (A50514)
Kinze 840 Grain...
2013 Chevrolet Traverse LS SUV (A50324)
2013 Chevrolet...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2015 MACK ELITE...
