pickin up leaves,what do you use?
   / pickin up leaves,what do you use? #12
I have a homemade tractor and a pull type lawn sweeper, I then dump them along my plowed garden and the riding mower blows them into the furrows which work up very nice next spring.Beats raking.
   / pickin up leaves,what do you use? #13
I made a cover plate that goes over the opening of the mower deck to block anything that tries to get out. Works real good for mulching leaves.
   / pickin up leaves,what do you use? #16
I mow most of them! When they get too thick, I use this set-up & use them for mulch out back:
   / pickin up leaves,what do you use? #17
Cyclone Rake Z-10
   / pickin up leaves,what do you use? #18
No not really :D
But, I am interested, what do you guys do with all those leaves? Shred and mulch?
We just leave them in a pile in the woods. They compress down to about 1/4 their original size by spring. Sometimes I take the pallet forks on the tractor and push them back into the woods further and turn them over at the same time. Then I get the worms from the leaf pile and go fishing! :thumbsup:
   / pickin up leaves,what do you use? #19
I'm using this Jacobsen 72 in,sweeper.12 hp kohler.Picks up leaves,sticks and even some acorns
No not really :D
8HP Track Vac fed by MMM behind Mighty Mouse. Shreds leaves nicely. We do acres around the edges of our fields. They go in the manure pile for composting.
larry
   / pickin up leaves,what do you use? #20
I just lawn mowed them and let them compost in place. Don't just let them lay. I used to have a couple of maples and when the leaves dropped they'd be knee high walking through them, then I'd run a lawn mower and that sucker'd be spitting out a solid stream of leaf bits. Then rake it out all nice and even. Easy on me and good for the yard. I had some s**t hot grass then.
Same here, put on a mulching plug and go over them 2 or 3 times. done it when leaves were higher than the deck but as much as yours. One day later all disappeared - good for the grass, good for my back, why pick them up?
Harry K
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
2021 CATERPILLAR 416 BACKHOE (A50458)
2021 CATERPILLAR...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
