mapper
Never heard of that, looked it up. That's absolutely a good idea and I hadn't even considered a need for something like that. I would hate to put in all that work for a solution to get head up to speed without damaging the PTO clutch, only for it to be destroyed by an unexpected shutdown of the tractor. Thank you very much for the suggestion! I will do it!
Most modern tractors have an over running clutch built in. If you have run a brush hog or similar attachment and heard a rapid clicking sound when cutting the throttle or if you can engage the PTO with the engine off and still turn the PTO stub shaft in the clockwise direction, your tractor has an overunning clutch.
