Picked up a used Stihl MS261
   / Picked up a used Stihl MS261 #61
Now those first 500 limited run of the 500 with the ID tags will bring the most someday.
   / Picked up a used Stihl MS261 #62
What does PHO weight stand for? I assume no bar and chain?
   / Picked up a used Stihl MS261 #64
Like this is PHO dry.
Then 20" 3/8 empty tanks.
Then with full mix oil and 20" 3/8 set up.
   / Picked up a used Stihl MS261 #65
They get heavy all loaded up!
I put the lightweight bar on my 500i and love it now.
I’ll never do anything but a lightweight bar from now on
   / Picked up a used Stihl MS261 #66
I upgraded from a 250 to the 261 a few years ago, definitely a great saw and for $300 you got a hell of a deal.
   / Picked up a used Stihl MS261 #67
Here is a G888 which is a clone of MS880 Gen2 the latest versions before 881 came out. PHO dry.
Here is PHO weight.
Then with 36" Cannon bar in 3/8 063 cant recall DL count.
But even b+c a ton. Think I got just bar weight too.
Then with whole thing mounted and filled up on both tanks.
   / Picked up a used Stihl MS261 #69
How often do you use your saw. I used mine recently but it hadn’t been used for several months and it took several pulls. Next time I used it 3 pulls got it. I usually do full choke and on the second pull it starts to run then dies. Then half choke and it starts. The key is to drop it to half choke if you hear it start to run a little or pop. Or there may be something wrong with your saw.
I use it most weekends throughout the year.
   / Picked up a used Stihl MS261 #70
If you use it that often something’s not right. Mine usually starts on third pull and the first pull when warmed up.
IRanch Mini Excavator Auger (A57149)
IRanch Mini...
Giyi Stump Bucket (A57149)
Giyi Stump Bucket...
2012 Ford F-250 Pickup Truck, VIN # 1FT7W2B69CEB80936 (A57453)
2012 Ford F-250...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
PORTABLE AIR COMPRESSOR (A58374)
PORTABLE AIR...
PALLET OF DOORS (A58374)
PALLET OF DOORS...
