Picked up a disc harrow...
/ Picked up a disc harrow... #1
Turbys_1700
Elite Member
Balls Creek, NC
New Holland t4.75
I picked this harrow up yesterday. I needed a larger one for the 75 and this one came up on Craigslist within driving distance. 10 footer with 9" space between 20" disc. No scrapers but need to replace two of the disc. 3x3 square time with 1-1/8" axle. Don't know the manufacturer. Of anyone has any insight who it might be or have any information on it I would appreciate it. 00n0n_82YILMS0rlZ_600x450.jpeg00G0G_4wFxMZauH3_600x450.jpegIMG_20180706_123530041.jpegIMG_20180706_123530041.jpegIMG_20180706_123538351.jpeg
/ Picked up a disc harrow... #2
Agri-Supply has a wide selection of discs if you are looking for replacements.
Yes. I bought a couple for the front. Thought that I would get the disc broken down first then decide which ones to replace. May go ahead and do the fronts. The rears look OK.
/ Picked up a disc harrow... #4
Looks like you can fold it for transport. I've seen that before, but I can't recall the brand name. It's not something you see very often in a 3 point disk.
If all you need are blade, most any tractor dealer should be able to find those for you from someone like Becknell. Becknell does not sell to the public. Wholesale only.
How much did you have to give for it? I've been looking for something similar.
I got it for 600. The 3x3 beams appear to be solid stock. I guess it's a pretty old model.
/ Picked up a disc harrow... #6
That's a pretty good price. If all you need is two discs and some grease to get her going, you did very well.
A new one built like that one now is a lot of coin. Several thousand dollars easy. It's one of the heaviest mounted used disc I've run across.
I checked last night. The harrow is made out of 3x3 tube wall measured at 3/16". I would like to know the manufacturer to get the specs on it. The owner purchased it at an estate. The estate had another red offset disc that was an Athens. That is what he thought that it was. Could be an older model. Their current line up is made different. Perhaps and old precursor to the current model 55.
/ Picked up a disc harrow... #9
Ok - I have to ask. What is the difference between a disc harrow and a disc plow? This one is so heavy with large serrated blades that I would say is a disc plow but where is the line drawn?
/ Picked up a disc harrow... #10
$600 is a great price. I would have bought it for that price in a heartbeat. Keep searching the internet and eventually you will find what brand it is.
I don't think there is really a difference. Some people refer to is as a plow and others as a harrow for the same implement.
/ Picked up a disc harrow... #11
A true disc plow has very large diameter discs mounted on a frame very similar to a moldboard plow. It is a primary tillage tool. Like many things, the definition has stretched over the years and may now include what used to be called a plowing disc. A plowing disc is a very heavy disc harrow used for primary tillage and configured similarly to either a tandem or offset style disc harrow. Turby’s new disc is not a disc plow. Most of us would not call it a plowing disc, either.
/ Picked up a disc harrow... #12
disc harrow is the 'second' step in plowing. It can be used as the first step as well.
A true disc plow has only 1 row of disks and all angled the same way.
We used disc plows when I was a boy. Worked really well in trashy ground. Did better than a bottom plow. We had a high clearance bottom plow that handled trashy ground better. We mostly plowed in the fall and harrowed in the spring followed by a chain harrow or log to smooth then drill. Plowing in the fall wet was of no consequence. Don't want to do it in the spring. Used a finishing disc and also had an 8 foot offset Taylor Way. Our disc harrows were either Taylor Way or Athens. Good implements.
Kubota Zero Turn Lawnmower (A65579)
Kubota Zero Turn...
Gravely Walk Behind Tractor (A65640)
Gravely Walk...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
