Pick-up Truck Bedliners
/ Pick-up Truck Bedliners
Thanks everyone for your input. I've learned enough at least to investigate the spray on stuff.
/ Pick-up Truck Bedliners #22
One place the slide-in models should have an advantage is in denting... If that matters anymore... I think all the trucks are doubled walled these days...
/ Pick-up Truck Bedliners #23
I'm glad to read that someone else uses their truck as a truck. My father-in-law cringes at the fact that I haul stuff in my truck, throw it in and go. He's afraid I'll hurt the resale value, but when you keep a truck for 10 years or more who cares. I will admit that I do have a spray in bed liner though Toro is the brand, great stuff. I will also admit that since I have had the truck for almost 2 years,2000 Dodge Ram, that I have only washed it twice and 1 of those times was by the dealer. But to be really honest the Dodge is no where near the truck my 1986 Nissan is 246000 miles and still going strong.
Solo
/ Pick-up Truck Bedliners #24
My bedliner already had the liner molded so that all the hooks were accessible.
/ Pick-up Truck Bedliners #25
Ranjar,
You might want to check out the bedliner threads on http:// [url]www.ford-diesel.com [/url]
even though you did buy a Chevy... /w3tcompact/icons/smile.gif
Seems like a lot of guys over there are using the XLiner brand.
When I got my new F350 in December I ran down and put in a plastic liner ASAP.
It was around $400 tops. Easy to put in and take out if I need to. No drilling it
just snapped into place. Very nice.
Check out the thread on Ford-diesel. I think most of the bedliners are discussed
under the "upgrades and aftermarket" area.
Hope this helps...
Dan
Thanks Dan. I'll check out the website. Cowboydoc -- you're right on those pre-drilled holes. From what I've seen all Duraliners and Pendaliners have those holes pre-cut by the manufacturer to accommodate the tie-downs.
/ Pick-up Truck Bedliners #27
I've had two pickups with duraliners. The first was an under the rail model and I had no problems with it. I did need to pull it out about every two years and paint the bed because of rust. My second has an over the rail model. I was driving on the highway last summer when this blew out of the bed and almost hit traffic behind me. I was lucky it ended up in the median, didn't hit anyone, and wasn't damaged. It is now tied to the front tie downs with rope so this can't ever happen again. My next truck will have a spray-in.
Timd
/ Pick-up Truck Bedliners #28
I don't worry about rust in the bed! Ain't got nuttin' to trap the water under, no spray in to develope a hole and allow water to seep underneath, no worries along those lines at all.
Scratches? I have oodles of them! Dents? There's a few! Worry? Nope! The inside of the bed may look like he.. , but that is NOT a worry...it just means the truck has been paying for itself.
I will sling something over the side of the bed and let it thump down, not caring if it 'mars' the finish vs oh so carefully spending extra time to place it 'gently' in the truck. Concrete pier pads, cinder block, whatever.
A few times, that 1/2 ton has had around 3000 lbs in it of various materials, and waddled off home. Works for me!
Many of you have seen the pics of the RAM and Ol' Grumpy, and I cannot stress the fact enough, it looks good on the outside, and doesn't hurt the value of the p/u. Plus, you save time and other costs, ie, you don't tear up your liner, or worry about the insert blowing out of the bed at 70mph going down the hiway. Seen it happen a few times...and they don't hold up to 18 wheelers worth a hoot.
P.S. - Save your bucks, and when you are ready to move on to a new truck, then spray a bedliner in at that time...if you still want to.
/ Pick-up Truck Bedliners #29
Scruffy, Not sure about your resale value thing, but that's not my point. After spending 30K for my Ranger in 1996 , I wanted to keep it in as best condition as possible. No, I don't put down doileys under the things I transport. I carry my firewood with my truck, and it usually gets launched in from a considerable distance.
As for it being slippery, there are pros as well as cons.
I can see getting along without a bed liner, but pushing the idea that you shouldn't get one to save 200$ doesn't wash with me.
Painted work surfaces are a bit of an enigma. I laugh when I see a brand new loader on a tractor.
/ Pick-up Truck Bedliners #30
If you have to take the bed liner out to repaint the truck box because of rust whats the purpose of the liner??
Egon
/ Pick-up Truck Bedliners #31
I'll have to admit that I tend to agree with scruffy on this one. No bed liners or spray ins for me. But I do have a rubber bed mat in my truck. My dog was really proud of it when I got it because now it doesn't take near as much effort for her to stay in one place while she rides in the bed./w3tcompact/icons/wink.gif
/ Pick-up Truck Bedliners #32
I've never had to repaint my bed or had it rust one bit from using bedliners. I take mine out in the spring every year and wash underneath of it and wax the box. My main reason for having a bedliner is the dents that you get in one from hauling stuff and the ease with which you can slide stuff in and out or lock it in with the 2x4's. Mine is just as much function as it is protection.
/ Pick-up Truck Bedliners #33
Paul, wonder in to your friendly dealership, (in a farm/agricultural/timber area) and simply ask them what kind of a hit does a pickup take value wise, IF the interior of the bed is scratched up from use. Of course, put the provisio that the exterior paint/body is in nice shape, and the interior of the cab is in nice condition.
I've had them flat tell me that it makes NO differance in the value of the rig, providing the mechanics and body, etc is in good condition.
The only reason to add the spray liner when selling (if personally selling it) is the same as the reason you spent a couple days detailing it in the first place....to get the highest price possible out of it.
Note: I've never bothered doing anything to the inside of a pickup bed...other than cleaning. Couldn't see spending 200 to make .... maybe a 100 more.
Have you seen commercially done spray liners peeling? I have, ugly too! I've also seen them leak moisture under them, and rust out an area.
I've also spent around a thousand redoing a bed with teak boards just for the 'look', but then, I wouldn't put anything back there either! One p/u I had, never, ever, hauled anything, except a custom made topper. I borrowed my Dad's truck to take stuff to the dump. Truck had less than 7000 miles on it when I sold it ... only six years old at the time. Absolutely worthless as a truck, but nice at the drags, and car shows!
The current operational theory that I operate under is: Buy it, USE it, sell it. No extra horse pucky along the way, except to add visually appealing touches, which are very minor in cost.
/ Pick-up Truck Bedliners #34
If you totally beat the dog crap out of the bed you can cover it with a slide in liner when you go to sell. That's what the dealer does. You would be suprized what's under some of those bedliners on the used car lot.
/ Pick-up Truck Bedliners #35
Cowboydoc:
It's a great world when we can all express our opionions and have a choice of options to meet individual needs.
Egon
/ Pick-up Truck Bedliners #36
It sure is Egon. Now if we can just keep the bleeping govt. from screwing that up we'll be just fine!!
/ Pick-up Truck Bedliners #37
Brad, I just bought my old '81 F250 in October '96 and it had a brand new slide in bed liner. When I was looking at it, I told me wife I'd bet it had holes in the bed./w3tcompact/icons/laugh.gif However, I looked to see and was surprised to find no holes; don't know why the dealer put that liner in there, but I've still got it. It does let stuff slide in and out easier.
/ Pick-up Truck Bedliners #38
Like quite a few others ... I have a truck that I use as a truck ... not a lifestyle statement.
That said ... there were, to me, still a lot of good reasons to keep the box from falling apart. It's pretty damp here in Michigan and I could see the scrapes starting to rust as soon as they were made (unlike dry Alberta where I never really worried about the bed).
Still ... our old Ford is now 24 years old ... so paying $450 for one of those spray jobs was out of the question (and the rubber mat just kept the water sitting underneath instead of drying) ... so I took the cheap way out ... spent quite a few hours cleaning the box completely (one full box of TSP) ... and then painted it with the kits they sell at TSC and auto shops.
No regrets ... it has a couple of minor scrapes that I need to touch up after 19 months of very hard use. While I don't haul a lot of rocks and stuff ... most of the use is hauling bedding and hay ... it does get used to haul equipment which is rdagged on and off.
If I were to break down and buy new (which'll be after this one gives up), I'll go for the professional spray job ... but this is working out well!
/ Pick-up Truck Bedliners #39
A few things to ad...
Plastic liners are not recommended with campers; it allows them to slide too easily.
When I removed the liner in myt old truck, there was a lot of wear and corrosion from the moisture it held in.
Plastic liners are dangerous around gas cans. The static can cause the gas to ignite. One of the firefighters at our station warned a guy at a gas station. As he walked inside to buy gas, he heard a boom. Came back out to see the guy got burned when he filled the gas can that was sitting in the back of the truck...
/ Pick-up Truck Bedliners #40
<font color=red>When I removed the liner in myt old truck, there was a lot of wear and corrosion from the moisture it held in.</font color=red>
Robert,
I just bought a new Dodge 2500. Couldn't resist, big rebate and fairly low financing along with 100,000 mile warranty. I recall a local camper dealer telling me a pad was available for placement under the bedliner. It breathes to prevent rust and provides a barrier against abrasion. I bought a Dodge liner with my truck, which is made by Penda. I am going to check next week with that same camper dealer to see if he still sells those mats.
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
John Deere Metal Decorative Sign (A64557)
John Deere Metal...
TRUCK RAMP (A64556)
TRUCK RAMP (A64556)
2014 John Deere 650K LGP Crawler Tractor Dozer (A64553)
2014 John Deere...
2025 Hercules 40 Gun Safe (A64557)
2025 Hercules 40...
JOHN DEERE 8530 TRACTOR (A65054)
JOHN DEERE 8530...
