Photo of Yanmar Keys
   / Photo of Yanmar Keys #1
Tractors4u
Elite Member
Athens Alabama
Deere 4310, Kubota L355, John Deere SST18 Spin Steer, 2006 Polaris Ranger
OK guys I am going to help you out. All this key talk is driving me nuts. To save you guys the hassle of trying to discribe you key to Len, Ernie or anybody else, I am posting a picture of the 3 most common Yanmar keys. Keep in mind that sometimes the Japanese farmer may lose his keys and replace the ignition switch with a generic switch and key. I have had a Yanmar with a Shibaura ignition and key and etc, etc.
The left key is very common. It is what you would call a double cut. The reverse side has TR on it. It is the key that fits the JD 850, 950 etc.
The middle key is probably the one I see the least of. It is single cut. On the reverse side the blade section is smooth with no grooves. The reverse side also has Yanmar on it. The side shown has the number 633 stamped in it.
The next key is very common. It is single cut. Has the words *** San on both sides and the number 30 stamped on the front side.
I hope this helps.
   / Photo of Yanmar Keys #2
I have the middle key, it came with my Iseki TS2810. The back side has YUSHIN SEIKI printed on it.
CKS
   / Photo of Yanmar Keys #3
Thanks Brent I have seen all three styles in every model Yanmar over the years
   / Photo of Yanmar Keys #4
Thank you, Brent! /w3tcompact/icons/cool.gif
   / Photo of Yanmar Keys #5
The key on the left is available at most JD dealers for about $2. Thanks for the pictures.
Ken
   / Photo of Yanmar Keys #6
My key matches the one on the left. I think I'll stop over at the JD dealer and see if they have any in stock.
Thanks for posting the pictures Brent.
   / Photo of Yanmar Keys #8
The key on the right is also the key they provide with a Marine Yanmar diesel,
You might check with the marine dealers and supply houses, the Yanmar is the most popular inboard diesel on 25 to 35 foot sailboats
   / Photo of Yanmar Keys #9
I've got another key that has a "yanmar" rubber grip on it. Guess it would be like the Key of the left if it was taken off. My other key is like the one on the left.
The type you are talking about what you would get if you ordered one NEW from Yanmar. I have some like that, but I figured that most folks would have the one with out the rubber grip.
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2019 RBR Venturi 380 (A53472)
2019 RBR Venturi...
6ft Pull Type Hydraulic Dirt Pan (A51573)
6ft Pull Type...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2018 Ford F-550 Flat Bed Truck, VIN # 1FDUF5GTXJEC35552 (A51572)
2018 Ford F-550...
