PHD hook up
/ PHD hook up #1
Arkie
south central Arkansas
2001 NH 33D
I attached my new PHD for the first time this afternoon,what a job! Can anyone give me advice on the best way to store this thing to where it is not such a pain to hook up to tractor?
I have been told to screw it into the ground a little to hold it up. I think that would encourage rust on the auger,wouldn't it?
Maybe it wouldn't rust enough to matter,but, it's new and i would like to take care of it. The wife doesn't let me buy new goodies very often. If anyone has a picture of a homemade support for a PHD, i would really like to see it. I could hang it from a tree limb but i have children around and i'm afraid it might fall.
Arkie
/ PHD hook up #2
Some manufacturers of PHD's make optional stands which specifically fit their implements, and I have seen a few made of landscape timbers and one made of welded drilling pipe, but I unfortunately do not have any pictures of these. I have fabricating one on my to do list, but I still invite a friend over to help me wrestle the beast onto the TPH for now.
/ PHD hook up #3
Hi Arkie,
I got a new Bush Hog 2102 a couple of weeks ago. What an awkward attachment this thing is. My dealer already had my 9" auger hooked up to it when I picked it up. What I did is strap the auger to a tree with a good quality motorcycle tie down after I unloaded it from the trailer. I was quite surprised at how easy it was to hook up to the 3-point hitch this way.
So what kind did you get, and which auger(s) did you get for it?
Spence
/ PHD hook up
My PHD is a Bush Hog brand . They do sell a stand for it but it's $120.00 plus freight. I'm not sure it's worth it if i can build something cheaper. However, my backache thinks it would be./w3tcompact/icons/smile.gif
/ PHD hook up #5
So which model Bush Hog? I paid $875 for my model 2102 with a 9" double flight auger. I paid another $175 for a 12" double flight and $30 for the leveling handle, both are still on order.
Spence
/ PHD hook up
It's a 2101 model with a 9 inch auger,bear claw tip. It worked great. I never thought of strapping the auger up to the trunk of a tree. I'll have to try that next time. I only have the one size auger right now, I thought the 9 inch would be a good happy medium. Do you think the positioning handle is necessary,i don't have one but thought about getting one.
/ PHD hook up #7
Hi, here are a couple of ideas, <A target="_blank" HREF=http://www.landpride.com/lp/products/pd15_specs.html>http://www.landpride.com/lp/products/pd15_specs.html</A>
I have attached a picture of a heavy duty one, it could be made with 3 legs and so on, depending on your PHD, good for ideas anyway.
/ PHD hook up #8
The Bush Hog web site has a good pic on the PHD page <A target="_blank" HREF=http://www.bushhog.com/agtoc.html>http://www.bushhog.com/agtoc.html</A>
/ PHD hook up #9
A couple more pics I found in the TBN forum files.
/ PHD hook up #10
If you don't need something as cool as the portable stand in the pic, why don't you just sink a 4 x4 in to the ground and strap the phd to it? I think I'm going to do that when I get a phd.
b249
/ PHD hook up #11
Maybe I'm dense here, but far and away the easiest way to attach and store a PHD is to take it apart! Everyone I have seen has a pin as a hinge that the gear box hangs on the frame with. Pull out this pin. With it loose, it is EASY to install the frame on the tractor. One man, 2 minutes. After that, you can move it around with the tractor and position it conveniently so you can stand the auger back up and put the pin in. Again, this is fairly easy for one person. A real heavy duty unit might be challenging, but still very doable. The leinbach model I used worked great and it didn't even come from the dealer with the auger on the head, or the head on the frame. VERY easy to handle in 3 pieces.
No way in he!! would I want one of those stands. Takes up to much space, wouldn't let me store the PHD inside. Of course if you use your PHD a LOT taking it apart might be more time consuming, but other then fence installers, no one I ever met used it enough to justify a god awful stand.
Hope this helps.
Nick
/ PHD hook up #12
I bought a stand with mine and glad I did - makes it so much easier - just back up to it like any other implement - I like the idea of putting wheels under the stand - then just push it anywhere ya want ... another item to add to "why I need to learn to weld"
mike
KIVEL PALLET FORK ATTACHMENT FOR MINI SKID STEER (A64553)
KIVEL PALLET FORK...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2015 John Deere CX15 (A64126)
2015 John Deere...
1991 Wilson Hopper Bottom Trailer (A66285)
1991 Wilson Hopper...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
Woods PRD7200 6' Finishing Mower (A66408)
Woods PRD7200 6'...
