Permanently Pinned
   / Permanently Pinned #1
kieramax
Port Alberni BC Can.
Kubota B20
I am new here and I need a bit of help. I am trying to replace the main swing pins on my BT 750. I have removed the Allen set screws and given it a few good wacks but it won't budge , Do I need to use a porta power or is there a secret trick. I have the new pins and there does not seem to be anything else to keep them from comming out. Thanks in advance.:(
   / Permanently Pinned #2
I just went through this with my backhoe ( different brand). After hours of messing with it using several methods, I was finally able to get it out with a large hammer and 1" drift. My next move was to use a hydraulic cylinder w/ cross tube cut off and try that...... If I owned a porta power, it would have been used after my first attempt to remove it after the initial hammer and drift failed to work..
Thanks for the info. I have access to a porta power but was leary of going to that level. thanks again
2012 John Deere 410K (A47384)
2012 John Deere...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2013 John Deere 824K (A52128)
2013 John Deere...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
