Permanent mounted solar panel
/ Permanent mounted solar panel #1
Capt.Ron
My RTV-X1140 has something draining the battery. I can charge it and it will last a week or so and then need to be charged or jump started.
I thought about mounting a solar panel on the roof to help it maintain a charge. Has anyone ever done that and if so, how did it work for you?
I'd love to see some links to the items you purchased for the job if you have them.
/ Permanent mounted solar panel #2
My Yanmar had a solar trickle charger panel bolted to the hood when I bought it. Apparently the PO wasn't much for diagnostics. It took about 20 minutes to figure out why the generator wasn't charging the battery. The solar panel will work, but you have to park the tractor outside for it to work. I keep the tractor in a shipping container, so the solar charger doesn't do much for the battery.
/ Permanent mounted solar panel #3
I bought a Solperk 30W solar charger with waterproof controller to keep the battery on my fuel trailer charged up. Cost was $90 off Amazon. I mounted the charger but not the panel. When I need to go into town to fill it up, I just unplug the panel and throw it in the truck till I get back home. Has lights to show charging and battery status. You can also run a small 12V work light off of it, using the provided plug. So far it is working great.
/ Permanent mounted solar panel #4
I have a solar panel on the roof of our daihatsu mini truck to keep charged up to full capacity, it works great.
Its about 8" x 12" but it does the trick.
/ Permanent mounted solar panel #6
A five to 10 Watt version (waterproof) should do the job. Any more than that and you'll need a controller.
/ Permanent mounted solar panel #7
Does your RTV-X1140 have a winch? If so, does the winch have a wireless remote control? If the answer is yes, my bet is that is what is draining your battery. The winch is usually wired directly to the battery, and the radio receiver for the wireless remote is usually connected to the winch. In this case, the receiver is on continuously, even if the UTV is switched off. You can add a bettery diconnect switch, and remember to turn it off when the UTV will not be used. As an alternative, if you can find the power wire to the radio receiver on the winch, you can put a switch in that lead and leave it turned off except when you are using the winch remote control.
/ Permanent mounted solar panel #8
I had a 10w solar panel mounted on the roof my Terex. Never could find the parasitic draw but the panel covered the loss. Note they do produce less when dirty so I would have to clean it occasionally.
/ Permanent mounted solar panel #12
You could also just mount a battery kill switch thru firewall into driver area.kill everything when not in use IMG_6449.png
2018 RAM 2500 (A65643)
Kubota L5030 (A64126)
240 Massey Ferguson Tractor (A61165)
240 Massey...
Frontier Forks (A64126)
Frontier Forks...
KUBOTA KX71-3 EXCAVATOR (A65053)
KUBOTA KX71-3...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
