Pellet stove advice needed.
   / Pellet stove advice needed. #11
I have the smaller Englander pellet stove found in the home centers. It works well. I had one problem with the blower and they sent out a replacement with no hassle. We burn 2 tons a year to supplement our oil heat. We also burn a little wood. For the $, the Englanders are decent units.
   / Pellet stove advice needed. #12
I am on my 3rd year with my Quadrafire 1200i (Quadrafire is made in Washington state I believe). It is an insert but it would not fit in the fireplace (one of those 'for show' metal ones.. not very deep or big) so I ripped out the fireplace and configured it to be a stand alone (extra $$). Pipe had to go up 2.5 stories and all installed it was $4500. Wife had to have the gold trim and all that.
I am on propane at over $2.00/gallon and pellets this year were $220/ton. On a BTU basis pellets are half the price of propane for the same BTU's. Based on this my payback is about 4.5-5 years. I have a 3000 sq ft house and burn between 5 and 6 tons per year. The stove can keep up until the day time highs are only in the 20's. Then I run the propane over the pellet stove... meaning I set the pellet stove high and the propane to what I actually want the house at. This way the pellet stove runs all the time and the propane only kicks on as needed. I went from 3-4 propane tank (500 gal tank) fills per winter to none in the last 3 years.
I buy all my pellets at Home Depot and use the 12 month financing. I have had bad pellets before. All softwood I believe out here... the lighter the color the better as it means less bark and trash. I get some great ones out of Canada called Fire Master.
Pay attention to the firepan size. Mine has a very small pan, just to empty the firepot. All the rest of the ash builds up inside and you need a $200 ash vacuum to clean it out (or lots of time to scoop it out). When running 24x7 I use slightly over 2 bags a day and have to clean out the stove weekly.
That feature to run the stove low versus turning it off sounds nice. It does take quite a while for the stove to really put out heat from a cold start.
Charles
   / Pellet stove advice needed. #13
If you wait until the end of the season that price will come down......I bought mine in the summer. We used about 900 gal of propane last year and at 2.75/gal this year it's not going to take long for the harmon to be paid off. Based on what we have used so far i figure we're going to use about 3 - 31/2 tons of pellets at 235/ton.
Jack
   / Pellet stove advice needed. #14
Here is the picture that was supposed to be in my first post.
Tripod stinks for picture hosting - Use photobucket, it's great!
   / Pellet stove advice needed. #15
Hey Tom, I had a slight different approach, I bought a good working used Whitfield Advantage II fireplace insert from the classified , It had 18 bags of pellets with it for a total $500. This was a few years back when people in my area were going to gas logs.
I did have to clean & paint it and make my own flu flange (very easy) but now my heat is set on 60* upstairs (cool for good sleepin) and 60* down stairs so the downstairs unit doesn't run much if at all... Our house has 6" walls which helps ...
This stove also runs through a bag a day, and my only complaint is it has a small ashbox , so every two days I have to shut it down to clean.. but the wife usually shuts it off during the day because she gets too warm (in her mid 40's :eek: )
I think it would probably be a good move to get a pellet stove new or used just keep the bearings on the brushless motors lubed up and it should give you good warm service...
Mark
   / Pellet stove advice needed. #16
sounds like you got a heck of a deal on that stove: i've wanted a corn/pellet stove for a couple years now, but the price scares me off: an now with corn being used to make fuel, the price has gone up so pellets would probably be cheaper? i'll keep looking for a used one, and maybe luck out.
heehaw
   / Pellet stove advice needed. #17
heehaw
Yep, I bought a pellet stove that can also do corn... figured 'dual fuel' would be the way to go.... oh well. ;)
Looked at a local dealer today that has Breckwell pellet stoves........he says they're great & no issues in 2 years on the demo model he uses to heat his display area. Quoted about $2200 for a "deluxe" insert with gold trim, cash & carry.
He wanted $450 to run a 4" stainless tube up my chimney tho............
Anyone have a Breckwell stove ?
TIA
Tom
   / Pellet stove advice needed. #19
Whitfield was bought out a few years ago by Lennox, so parts shouldn't be a problem. I have one of theirs, a PF-20 that has been working well for 2 years now. The Harmon's and the Quadrafires are very nice, as well as those made in Canada by Enviro Fire. I would say all 3 of these makes are built a little better than the Whitfield. Some of the cast iron models are much nicer. I did quite a bit of research before I bought mine, but I also got a pretty good deal on it at just under $1700 delivered, which ultimately made up our mind. I installed it in place of a freestanding wood stove.
I don't know how familliar you are with pellets, but the combustion process is powered by a blower on the flue outlet pipe. It places a vacume on the firebox which forces combustion air to be drawn in thru the burn pot under the pellets, from an air duct. Any leak in door or case seal will draw in air instead of letting smoke or gas out into the room.
One thing I wish I would have looked closer at was the combustion air inlet. You want one that is hard plummed all the way into the burn pot. IE, the only source for the combustion air is via a single pipe so you can draw all the combustion air from outside the house by connecting it to an external air duct. The Whitfield I bought has a small pipe for combustion air, but it is only thru the rear skin of the outer case, which is full of louvers and about as airtight as a birdcage. The actual combustion duct on the fire box draws it's air from the inside of the outer case, or basically from the room it is setting in.
Pellet stoves burn so clean by pumping a LOT of air thru the stove. I would say far more than a woodstove does. If the combustion air is drawn from the house, it is pumped outside via the flue pipe. This room air has to be made up from somewhere else, like any leak around a window or door seal with cold outside air. Our first season of running it was pretty chilly in the living room. The stove was pumping out heat like mad, but the outer edges of the room were always cold, way colder than they had been with the wood stove. I had to do some internal welding and ducting on this new stove to get the combustion source into a single duct that I could plumb to the outside. Once I could draw the combustion air from outside the house, it was much more comfortable inside.
I did not get the opportunity to take the sides off of the whitfield when shopping. The only one I found local, was a working demo and the store heater. The gentelman didn't sell Whitfield anymore. I found the one I bought on line from a supplier in Idaho. If I would have had the chance to look inside, this lack of ductwork would have been readilly apparent and taken it off my list. The rest of the stove is built pretty well, so the little bit of the pipe I saw comming out the back lead me to assume(as it was intended to) that it was hard plummed the the burn pot as in other stoves I have seen. Caviat Emptor... IT looks nice(wife liked this one's look) and after a little work by me, it is performing as well as any pellet would in our home, and the price was right. But I would NOT buy another Whitfield! My next vote based on performance VS construction VS Price was the small envirofire that had about the same 12,000 BTU output on low.
Another thing to look for is heat exchanger size. there is a second blower that pumps room air thru the heat exchanger tubes and back into the room. The size(surface area) of the heatexchanger is directly proportional to the efficiency More tubes are better. Most pellet stove heat exchanger efficiencies are in the area of 75-80% I found when I was doing my research, that some manufacturers advertised their stoves output by the ammount of fuel it burnt(in BTU) as this is a larger number and makes the stove look more impressive. Some listed theirs the more honest way by the actual heat output into the space. But since they all give burn rates in pounds per hour, this is easy enough to check out. Average grade wood pellets contain around 8500 BTU per pound. So a stove like mine that burns 1.8LB(around 15,300 BTU) on low only puts about 12,087 BTU into the room at the 79% advertised heatex efficiency. So the claimed 12K BTU on low was accurate. Usually some or all the parts to this equation are available in the stove info brochures, pounds burnt per hour, claimed heat output, or heatex efficiency, to see just how honestly the manufacturer is selling their product.
The above information is also handy in calculating the size stove you need. Most all the stoves I have looked at offer low, medium and high heat output levels. And I think with only one exception, all were reccomending NOT to run them on the highest setting for extended periods. They are also less efficient on the higher settings(more heat goes up the chimney) So you should size the stove to meet your needs on the lowest setting and the intermediate and high settings used only intermittently to take the edge off a cold room. Most all the stoves I have seen offer a thermostat option that turns the stove on or off for heat control. Some, like the Envirofire can also shift from high to low under thermostat control to maintain the temp in the room, I wish I had this feature, mine only does on or off. Since I don't run the stove wheni am not here, I don't even use the on or off feature.
Most all the stoves I have looked at are top fed, IE: The auger lifts the pellets up from the botom of the hopper to where they fall down a chute into the burn pot. I believe Harmon marketed a bottom fed version where the pellets are pushed into the bottom of the burnpot, which makes for a very steady and quiet feed method. I don't know if they make these anymore, but it didn't look especially safe to me, as if the power went out, and without forced airflow control, the potential existed for the fire to burn back along the pellets in the auger and ignite the pellets stored in the hopper. This is virtually impossible in the top fed design, which most all pellet stoves employ.
Another factor is noise. Mine sets in my living room along with the TV. It has 2 blowers and an auger motor, so it makes noise. It is not especially annoying, but it does add to the background noise level. One of the quietest stoves I looked at was the Envirofire Mini. It actually has insulation on the insides of the cabinet panels. Not for heat, but to dampen the blower noises and it was by far the quietest I have ever looked at(this one initially had my vote, but the wife didn't like the way it looked:). A insert model should be quieter, but look for insulation on the trim panels that will fill in the open space around the unit once installed in your existing fireplace.
Another issue may be necessary heat. My main source of heat was the woodstove that the pellet replaced. Pellet stoves require power to operate so I wound up building a small generator set for my home to keep the lights and now heat on. They don't take much power, mine uses about 400Watts in normal operation and about 700W when lighting. This was a little too much to feed long term with a inverter, so I went with a generator as this had other advantages.
Good Luck.
   / Pellet stove advice needed. #20
I did not find any recommending to not run them on high 24x7, maybe I did not look hard enough. I did see stories of control boards failing due to the constant high heat. My Quadrafire has the board mounted on a 'stand off' with lots or air circulation around it... barely gets warm.
I do wish mine had modes where you could leave the blower on high and run the stove on low/med. I could see where this might be an issue if you ran the stove on high and the blower on low as you could overheat the stove. Mine just has three modes low/med/high which controls both the blower and the stove.
I would expect to see better thermostat/stove controls come out. The existing thermostat wires could easily carry a digital signal between the two allowing more than just on/off low/high/med. Of course this requires a special digital thermostat and controls in the stove so more $$
I called on Propane the other day and it is $2.629 per gallon. My propane furnace and pellet stove are both about 80% efficient. On a straight btu to btu basis each $229 ton (including $9/ton for delivery) of pellets offsets almost $470 worth of propane which keeps about $240 in my pocket. ;)
This year is the 3rd year of operation with the pellet stove. I spent $4,500 to get it installed and by the end of this winter it will have offset about $3,000 in propane costs.
What other improvement can you make to your house that will give 22% Return on Investment (ROI) ??? :)
Charles
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
(APPROX. 15) UNUSED IRANCH GROUND PROTECTION MATS (A54757)
(APPROX. 15)...
2017 TAKEUCHI TB240 EXCAVATOR (A52705)
2017 TAKEUCHI...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
