Posthole Digger PD Auger Recommendation............
/ PD Auger Recommendation............ #1
gltrap54
Topeka,KS
B3200 Kubota
I'm considering an auger (9", I guess......) from TSC. I can catch one on sale for $109.... I know nothing about the quality of their augers, but FWIW, this auger won't get much use.... :confused3:
/ PD Auger Recommendation............ #2
Honestly, theirs are as good as any. The parts are mostly interchangeable between brands. When you buy a big name brand you 'can' get a better gearbox, but even then most are the same sort of China stuff. There are also various "features" such as hydraulic downforce that can be had. If I'm not mistaken, the TSC PDHs are rebranded Speco, which are good.
/ PD Auger Recommendation............ #3
My 12" farm store auger did 10ish acres of holes fine. Needed 1 or 2 new sets of teeth, but they are wear items. The holes at the top for the mounting pins were starting to waller out a bit, but not to badly & repairable if it got worse.
I now have a 12" that was 3x the price for my new hydraulic PHD. It's a much beefier auger for a 2" hex drive rig as opposed to the lighter 2" round drive. I use the new gear semi-commercially so a stronger auger is worth it now. I would be fine buying a farm store auger for my 5 acre personal project if I had to do it over again.
Thanks fellas! I'm sure the TSC auger will be OK for what I'm doing.....
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2020 Freightliner 114SD T/A VacCon VPD3611 Combination Sewer Jetter Vacuum Truck (A61573)
2020 Freightliner...
Lift cylinder for model 48 john deere loader
Lift cylinder for...
GMC 6500 (A63291)
GMC 6500 (A63291)
2016 26ft T/A Dovetail Flatbed Equipment Trailer (A59228)
2016 26ft T/A...
