Payne's Hitch Receiver
/ Payne's Hitch Receiver #1
CurlyDave
Elite Member
Grants Pass, OR
JD TLB 110
I don't know whether this belongs in Safety or Attachments, possibly a moderator could help me.
But, I need to bring everyone's attention to a serious safety issue with Payne's Clamp On Hitch Receivers.
I have one of these and use it on the 4-n-1 bucket on my John Deere TLB 110, which has the bolt-on wear edge. I use it to move and position my 16' enclosed trailer, which has an empty weight of ~2270 lbs.
No matter how tightly I jam the receiver against the bucket edge (it appears to me to fit as designed) I have two problems:
1. Any attempt to steer the trailer puts a side force on the hitch, which easily causes it to swivel, so that it is no longer perpendicular to the bucket edge. I have tried tightening the clamping bolt with all my strength, and placing one side of the receiver against one of the bolts in the bucket edge, but nothing helps the situation.
2. Last week I tried to position the trailer facing downhill on about a 15% grade. Obviously this meant that the trailer was pushing against the ball, and therefore the receiver. Well, the force caused the clamping bolt to unscrew, and the receiver swiveled completely against the bucket edge. It loosened sufficiently that I was afraid it would fall off the bucket. This was clearly a very unsafe situation as the only thing which prevented the trailer from rolling down my 1000' long, 15% slope driveway was the fact that it ran into the bucket of my backhoe.
The thing that caused a lot of pucker factor was that in order to get out of the situation, I had to chock the wheels of the trailer, and then get in between the trailer and the backhoe in order to get the trailer unhitched from the ball in the receiver.
No matter how well you chock the wheels and lower the tongue jack, standing in between a 2300 lb trailer, which wants to roll downhill, and an 8000 lb backhoe, with its parking brake fully engaged and stabilizers down, gets my full attention. The steel edges of that bucket look very hard and cruel compared to my frail human body. And the front of the trailer looks like a most unkind pusher.
Other than "don't use the clamp on receiver" does anyone have any ideas on how to prevent this situation from developing?
I sent an email to Payne's tonight and will post whatever reply I get.
To see one of these gadgets look here: Clamp On Hitch Receiver
/ Payne's Hitch Receiver #2
I would drill a hole though the receiver and the bucket so I could put a pin all the way through both, and if I was going to be near a slope I would find a way to chain the trailer to the bucket as well. that being said, on my dads massey industrial 35 he has a piece of 1/4" wall 2" box tubing welded on the inside middle of the bottom of his bucket and if I had a driveway like you describe I would do something similar to what he did.
Aaron Z
/ Payne's Hitch Receiver #3
That's a scary gadget and an expensive one to boot. ACZLAN has a good idea to come up with a through pin modification to keep that puppy from spinning.
/ Payne's Hitch Receiver #4
I had a problem with a homemade one that did the same thing. I used the safety chains and used a strap to go around the back of the bucket. As you turn the strap slides around but keeps the trailer on. I took a video of it but can't seem to find where I put it :mad: on my computer. Got photos, too... I'm sure in the same place as the video :eek: . I don't like moving a trailer without the chains hooked up to the vehicle.
/ Payne's Hitch Receiver #5
Looks like just plain poor design to me.
I don't like the idea of trying to manage a ton & a quarter of load with a clamp bolt and no way to stabilize the connection. I would not only change it to a through-bolt, but weld on some material parallel to the bucket edge.
Thinking about it a little more...
I don't think I'd continue to use it. I'd find or build something a bit sturdier with a positive attachment to the bucket.
Well, so far no word from Payne's.
I agree, if I am ever going to use it again, I have to pin it to the bucket somehow.
I may be better off learning to weld and getting a welder.
/ Payne's Hitch Receiver #7
This gadget looks just to handy to pass up and I ordered one.
I will try to "pin it".
I really don't want to remove the BH because I'll need the weight for traction and counter weight.
I plan to use it to try and launch and retrieve my 3500lb boat with a BX24.
I think keeping the big tires on dry land with weight on them will raise my chances of the BX24 pulling it out.
I'll report how well it works. I only have to tow like 50' per season.
Anyone know how far I can drive the BX24 into water before I get myself in trouble? (i.e. Transmission vents, Differential vents).
/ Payne's Hitch Receiver #8
Could you weld some "wings" on it like this? It would help prevent rotation during a "push" condition.
/ Payne's Hitch Receiver #9
I have had the same problem with a home made one myself. the 'wings' are a must. But I also made mine with a hole drilled in the bucket and pin through it.I trust this method far better that the 'clamps' on idea. I assume with wings and flat ground the clamp ones would do ok. But the pin or bolt through it is the way to go. I have also used this hole int he bucket to mount other attachments that I have.No regrets.
I sure hope you hear from them, because thats no cheap hitch...
Al
/ Payne's Hitch Receiver #10
I have one, but haven't tried it yet - because I had concerns exactly has you have described. My property is all 15-20 degree slopes
I think (2000 miles from home, so can't check) that it is only rated at 1,000 lbs. I didn't realize this when I bought it - and was hoping to use it on my 18' landscape trailer (~2000#) and, possibly (but not likely), for my 18' boat.
That said, I have considered it to not be a good option for transporting the trailer any distance around the property - figured would stick with the truck to get it near the parking area, then use it for final parking. Like an airplane being pushed or pulled from it's gate.
However, some of the suggested mods would seem to be an option to actually "tow" with it.
/ Payne's Hitch Receiver #11
http://www.paynesforks.com/
Our Light Duty Lift Ball Clamp has a 2,000 lb lift capacity, is 20" Long, with a 2" opening, extends 11" under the bucket, clamps 7" inside the bucket, and weighs 25 pounds. This will move your pintle, 1-7/8", 2", and 2-5/16" ball receivers. Available with a 1-3/4" stem or a 2" stem.
NOTE: 2" stem will not move 1-7/8" ball receivers.
Lift Ball Clamp
1-3/4" Stem
Price: $155.00
$20 Shipping anywhere in the Continental USA
Total $175.00 USD
Qty
Lift Ball Clamp
2" Stem
As best I can remember (I am only 500 miles from home) mine has a sticker stating a 1000 pound limit on it. I took that to mean that there was a 1000 pound tongue weight limit, not a 1000 pound trailer limit.
I would have no problem using the hitch receiver for moving trailers on level ground, and even for applications where the trailer is lower than the tractor (hitch receiver in tension), as long as the safety chains were attached to the bucket.
I don't think there would be any issue with launching and retrieving a boat for instance.
I will never again allow the trailer to be above the tractor when using this hitch.
P.S. I have had no response to my email from Payne's. Why do they bother to put a link to their email on their website, if they aren't going to respond?
/ Payne's Hitch Receiver #13
Unfortunately a lot of companies do this.
/ Payne's Hitch Receiver #14
Well, I just forwarded this thread to them, via their email address, with an invitation to join the festivities...:rolleyes:
/ Payne's Hitch Receiver #15
would this be the hitch in question?
Paynes Forks Ball Clamp with 2in. Stem | Tractor Bucket Forks | Northern Tool + Equipment
I see they have a small metal 'tab' on the back of it. I assume this is to hit the backside of the cutting end and keep it from sliding off. I would if possible add a piece of angle iron across the front of it to side against the cutting edge. this would prevent the hitch fro twisting side ways.
Hope this helps..I also wonder how tight they expect you to be able to clamp it.
Al
/ Payne's Hitch Receiver #16
for what its worth, I bought a very similar item off ebay buy-it-now from mid south for around $70. I could see the same issue, but I've found it handy for moving things around none the less.
/ Payne's Hitch Receiver #17
I bought one of these also and have the Same Problem.I will also try to contact Paynes in the ***** forks on monday.I agree this is a saftey issue on this product.Maybe a call to my local states attorney general might help,or a trip to paynes factory which is about a I hour drive from my house might be in order.coobie
/ Payne's Hitch Receiver #18
Sorry you had the same trouble. I see Curly has waited almost a month to hear from them. whether or not he has gotten a reply we don't know. But I think he is th type of member who would let us know. when they do notify him.
I sure cant wait to hear this response.
/ Payne's Hitch Receiver #19
I will let you know.coobie
/ Payne's Hitch Receiver #20
I just took a 12" chunk of 3" channel, welded a piece of 2" angle across it for the cutting edge to bear on and welded a receiver to the front of the channel. Bolted the whole issue to the bucket with a 7/8" bolt. The angle stops anything from spinning and spreads the weight of whatever is plugged into the receiver along the edge of the bucket. Probably worth $25, including the bolt....That commercial thing looks like a "one time use only".
x (A68191)
x (A68191)
Scag 36 Advantage (A64912)
Scag 36 Advantage...
2012 Chevrolet Impala Sedan. (A66738)
2012 Chevrolet...
Giyi Forklift Telescopic Boom (A64912)
Giyi Forklift...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
FIXED FIFTH WHEEL ATTACHMENT (A68842)
FIXED FIFTH WHEEL...
